Old 02-13-2009, 01:17 PM   #1
Split
Drives: 2008 Yaris Sedan
Question Does +43mm rub?
I'm about to buy some wheels for the yaris.
16x7 +43mm offset.
I know for a fact that +42mm rubs, and that +45mm does not rub. Do you think +43mm would rub? its only a millimeter more than the +42mm, but it might be just that millimeter that makes the difference?
Don't ask me if the car is lowered or not, because that doesn't make a difference.. having a full car with passengers and stuff in the trunk is the same as lowering, or when you go over a bump or dip hard-enough the suspension will travel just as low.
Split is offline   Reply With Quote
Old 02-13-2009, 01:34 PM   #2
Yaristwn
Yaristwn's Avatar
Drives: Yaris 1.5 Sport
16x7 +43mm offset.
Hi!
I am using a set of 16x7J, ET40 alloys with stock 195/50/16. No rubbing for your reference...
Yaristwn is offline   Reply With Quote
Old 02-13-2009, 02:06 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
how many of these threads does yarisworld need?
Old 02-13-2009, 02:08 PM   #4
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
I'm +42, 205mm tire, lowered on TRD, and no rubbing.
2006 Red Blitzed RS 5-door
Old 02-13-2009, 04:08 PM   #5
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
+42 ON 205/55/15 with teins and i rubbed when making u turns or cutting wheel hard....
Old 02-13-2009, 04:13 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
16x7, ET42, 205/50/16 will not rub on stock suspension... front or rear.
Old 02-13-2009, 04:50 PM   #7
Split
Exclamation
suspension has nothing to do with it. it just means the factory springs/shocks have to be compressed an additional 1" before rubbing occurs. if you bottom out aftermarket suspension or factory suspension, you end up at the same height.
Old 02-13-2009, 04:54 PM   #8
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
strange. when I changed suspensions I stopped rubbing.
but you're right suspension has nothing to do with wheel fitment.
if you're lowered on aftermarket springs there is a chance you'll rub constantly (FYI, that's bad).
where if you were stock you'd only rub under heavy load.
that's the reason we ask.
some people are ok with little rubbage after serious dips.
Rub constantly = Bad
Rubbing only a little at certain times = ok for some people
not rubbing ever = good.
to determine such things knowing your suspension setup is a factor. :)
and a car on DF210s with a full hatch is very low. :lol:
Russelt3hPirate is offline   Reply With Quote
Old 02-13-2009, 04:31 PM   #9
Russelt3hPirate
l33t3st Asshole
i run a 15x7 +25mm in the rear and i don't rub with a 205/55/15.
Old 02-13-2009, 04:32 PM   #10
Russelt3hPirate
l33t3st Asshole
Are you lowered?
Old 02-13-2009, 04:51 PM   #11
Split
i'm looking at these wheels now, since they are only 15lbs and come in 16x7:
i was trying to find rota subzero's in full royal gunmetal but no-one seems to carry them, and its apparently 6-7months to special order direct from rota.
Old 02-13-2009, 04:55 PM   #12
Russelt3hPirate
l33t3st Asshole
the 57Maximums are great wheels, I had a set on my STi.
do it post pictures and tell us how you're rub free.
oh and if you do start rubbing you can always add some camber, the yaris likes a little camber :)
Old 02-13-2009, 04:58 PM   #13
Russelt3hPirate
l33t3st Asshole
Also, I rubbed pretty badly with my setup originally but that was b/c my toe was sooo fucked up from the suspension install that it caused rubbing.
once the toe was fixed I had no more rubbing up front. :)
Old 02-13-2009, 05:28 PM   #14
ddongbap
Not all tires are created equally.
Old 02-13-2009, 05:36 PM   #15
Split
^ yea that's true too. i was planning on doing a 205 so that's why its important that I run a +45mm offset. Are there any wheels with a +48mm offset? That's closer to stock.. stock is +52mm IIRC. Seems like the higher of the offset the better, for almost any car. I know with my Mazda3 I ran a +50mm offset to fit 225/40R18's. On my lexus, if i run +50 i can get 245's in the front, and with a +53mm in the rear I can run 275's.
I dont understand why aftermarket wheels always have such low offsets? These wheels are for my girlfriends car, so in the end the style decision is up to her. I like the Gram Lights, but I think she wants Rota SubZero's in a Full Royal Polished finish. (i'll at least get full royal gunmetal, so its not super bright bling bling)
Old 02-14-2009, 04:56 AM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
this made me lol because i'm sitting here thinking "why do aftermarket wheels have such HIGH offsets?"
Old 02-13-2009, 05:43 PM   #17
Russelt3hPirate
l33t3st Asshole
you could get her the original Racing Heart wheels too they come in a nice offset for 16"
the key is the "correct" offset for the given vehicles usage, suspension, alignment, and tire choice.
"higher" isn't always better for the offset especially when you're upgrading suspension as alot of coilovers are larger then the stock struts which can cause rubbing issue on higher offset wheels.
why do you want a 205?
Old 02-13-2009, 05:54 PM   #18
Split
i dunno.. i guess 195 would be okay. Just 195 seems so small ?
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
want 2 lower with tein but have tyre rub HELP! MR. CANTON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-24-2007 04:16 PM
Got new wheels, tires, and springs installed. largeorangefont Wheels, Tires and Suspension Forum sponsored by The Tire Rack 44 09-22-2007 04:21 AM
