![]() ![]() ![]() Drives: 08 Yaris Join Date: Oct 2008
DRL Disabled If I Install HIDs?
First, I did my search beforehand and nothing related to this topic came up, so I decided to post one for myself and for future references.
Up here in Canada, DRL (Daytime Running Light) is mandatory and illegal without them. That being said, I am wondering how to solve this problem as I decided HIDs to be my next upcoming modification. I am planning to purchase one of those H4 Hi/Lo conversion kits (right at this point I will put my flamesuit on just in case) but I'd like to find out some info about solving DRL problem before I make up my mind. Any info will be appreciated, thanks!
RIP Yaris, I will miss your superb handling a lot. darkmoon87's picture thread http://www.yarisworld.com/forums/showthread.php?t=10013 |
SIPNDEW
having DRLs can and may lead to premature failure of the HID kit.
![]() ![]() Drives: 2007 Yaris Supercharged Join Date: Nov 2008
there is a drl ecu right underneath ur ignition cylinder... u can just disconnect that connector..... make sure after its disconnected that ur headlights are working properly...
SIPNDEW
how are you going to get around the DRL elimination being illegal?
yah it is illegal not to have drl in canada.... i have my stane alone fog lights...
so i turn my fogs on as my drl... |
darkmoon id ur having troubles looking for that drl ecu... the DIY explains the steps pretty clear...
In Canada, no new car can be sold without DRL, but AFAIK it's not illegal to disable them.
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
they have digital ballasts now... cause my friend has a charger and i went to my buddy and got a set of plug n play eagle eye hid's and he told me that i dont have to disable the drl's and they work so.. if u need more info ill call my buddy who is the owner of a sound/rim shop
"It hurts more when its wet" |
#9 | |
Many higher class luxury car use their HID as DRL. There shouldn't be a problem using the HID as DRL. http://cgi.ebay.ca/HID-FUSE-RELAY-HA...3A1|240%3A1318 |
| Where is my DRL Module......? Help With HID's | The Architect | DIY / Maintenance / Service | 6 | 05-20-2009 10:21 AM |
| DRL and HID's? | dimsum69 | Cosmetic Modifications (Exterior/Interior) | 5 | 01-12-2009 03:30 PM |
| where can i install these power locks? | songa | New England | 1 | 12-04-2008 12:41 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
| DRL enabled with HIDs... sort of... | Galavoxx | Cosmetic Modifications (Exterior/Interior) | 0 | 03-28-2007 08:26 PM |
