Old 04-07-2009, 09:27 PM   #1
jonismyname
Drives: 08 liftback 5spd
BIG driving lights.... how?
i want driving lights. well, i have driving lights, mounted hanging from the upper lip of the lower grill. this is too low. i also used smaller rectangular lamps in my attempt to keep it small. i don't like those.
i want 7" lamps. big gawdy ones that light things up. hella makes some great 7" driving lights, and even a few very nice 4" or so setups.
has anyone ever mounted these on a yaris? other than the rally car with a specific molded piece above the grill?
has anyone deeply considered modifying the grill, to recess a set of wonderful driving lights?
the problems i see-
-weak mounting (bumper cover material) due to the constant slope of the front end
- anything will stick up and out
light enough lamps should be okay with the mounting issue... my smaller maps have no issue..
but the sticking out too far thing, i don't quite know how to fix that.
im thinking, new grill, cut holes, mount less huge lamps inside the grill? or at least 1/2 way into it so they're sitting behind a bit? then i could mount to the actual bumper?
HB grill for $28- http://www2.partstrain.com/basket.ph...9920733-853290
any idea's?
i also have other options- projector driving lights that are ultra small
http://store.summitracing.com/partde...rt=GTE-64631-5
maybe with a HID kit down the road?
or i could go with depo headlamps with a HID kit?
i just dig big bright lights, and do a fair amount of back road driving (deer season...)
jonismyname is offline   Reply With Quote
Old 04-07-2009, 09:34 PM   #2
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
Architect is running depo with hid's... there is a thread about it.... have a search...
More light can be taken from the fogs with hid... so, if you have projectors with hid and fog with hid... I guess that would be a lot of light
Old 04-09-2009, 12:36 AM   #3
kenkyd
kanye
Drives: 11 Corolla S
Send a message via AIM to kenkyd
i just saw a yaris here in buf that had 2 (probably 5 or 6 inch) hella spot lights in front of grill. didnt stop and look how he mounted them though. i mounted them on the bumper frame on my last car.
kenkyd is offline   Reply With Quote
Old 04-09-2009, 04:46 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
i don't know man... when you say you want big light... i think of this:
is it all that necessary ? i don't think you are supposed to use them in town... It might be understanding if you lived in rural areas (see farms), but then... is this a must ?
Old 04-09-2009, 11:17 PM   #5
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Sorry, I can't stop laughing.
Old 04-10-2009, 01:52 AM   #6
AlainMikli
AlainMikli's Avatar
Old 04-09-2009, 05:15 PM   #7
ChinoCharles
Drives: LB
Its too much? A tow hook isn't too much? LOL
DOOOO ITTTTTT.
I think my favorite member Yaris T Sport has them. Might be wrong though.
Old 04-09-2009, 05:58 PM   #8
SailDesign
Drives: .
This was my old VW Fox - I still want to do something like this, but am not doing a thing until I can figure out how to do it RIGHT.
Old 10-03-2009, 09:28 PM   #9
frownonfun
frownonfun's Avatar
i think a couple small lights like that would look nice... i'm thinking of constructing a small rally bar coming up from under the front bumper to mount the lights on. just gotta find some place under the car to mount the bar.
I crush you like tiny clown car, because you are clown, yes?
Old 04-10-2009, 01:55 AM   #10
YarisSedan
Drives: 08 Yaris Sedan
spider
Old 10-07-2009, 04:55 PM   #11
Prohibit
Verbieten Sie
Prohibit's Avatar
Drives: 2007 Liftback
Send a message via AIM to Prohibit Send a message via MSN to Prohibit Send a message via Yahoo to Prohibit
If he wants 50 of them on front of the yaris, more power to him.
Hatchback Purist? Be sure to drop in and register. New forum with a great clean design and potential.
Prohibit is offline   Reply With Quote
Old 09-28-2010, 06:47 PM   #12
jonismyname
resurecting this thread, was googling for ideas when i found my own thread lol!
still trying to figure this out, had a set of lights mounted in the lower grill for a bit but got rid of them.
fall makes me want more light... i'm petrified of deer and drive too fast for conditions from to time... and i'm a light dweeb.
any new idea's? i think i'm still looking at cutting into grill... i can't think of any other way?
i like bigger reflectors as i feel they make better light...
Old 09-28-2010, 09:20 PM   #13
I need to do something similar with Crashy to get light over the plow. When I get around to chopping her top, they'll be mounted to the roll cage. Until then I was thinking about a roof bar, like just the front section of a roof rack.
Old 09-28-2010, 10:15 PM   #14
jonismyname
PAR36 bulbs and housings would be perfect for something like that on a budget. sealed beam bulbs are cheap, buy/mount one cheap housing and swap bulbs as you like. rubber housings are about 8 bucks, bulbs 8-10 each from led's to floods to 100w airplane landing lights. lots of options.
i've concluded the only way i can make it work is to mount them in the front grille. i'd need to find a hosing that can mount flush to the front of the grill and cover the holes i'd need to cut. only problem is i'd have to way to aim or adjust the beams...
Old 09-28-2010, 11:09 PM   #15
So, the grill mounting is so they are low enough to be legal for normal road use?
Old 09-28-2010, 11:21 PM   #16
jonismyname
i like the looks of the car, and am trying not to interfere with it too much. i had driving lights coming out of the lower grill, and only removed them because they stuck out by themselves. without fabricating a light bar i'd like them "sunken". garm's fog lights are good, but i want to be able to change bulbs to find what i like... different wattages and beam patterns...
if i only had a crashy...
Old 09-29-2010, 01:32 PM   #17
mari
Drives: 2010 sedan
easy. make a light bar that pokes through the upper grill mesh and bolts into the steel crash bumper behind the plastic bumper cover. like this http://web.mac.com/jonnieoh/My_MINI_...ts_How-To.html only you can do it out the top grill and not the lower one. lucky for us, the lights wont interfere with the hood opening like some cars.
or, if you want real lighting, mount this in the upper grill http://www.rhinopartsandperformance....-LED-LIGHT.htm and you wont have any problems with seeing.
mari is offline   Reply With Quote
Old 09-28-2010, 10:29 PM   #18
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
do like i plan on doing, mount the lights to the back of the car facing behind you, so when all those idiots think it's a good idea to ride up on your butt at night, you hit the lights!...probably not safe, but still thinking about it
Club SHIFT
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 10:10 PM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Tinting lights & windows pricing wiirenet Cosmetic Modifications (Exterior/Interior) 15 03-22-2009 01:09 AM
Bad Driving Techniques Altitude General Yaris / Vitz Discussion 10 02-10-2009 06:26 PM
