I need to do something similar with Crashy to get light over the plow. When I get around to chopping her top, they'll be mounted to the roll cage. Until then I was thinking about a roof bar, like just the front section of a roof rack.
#2 | |
![]() ![]() ![]() Drives: 08 liftback 5spd Join Date: Oct 2008
i've concluded the only way i can make it work is to mount them in the front grille. i'd need to find a hosing that can mount flush to the front of the grill and cover the holes i'd need to cut. only problem is i'd have to way to aim or adjust the beams... |
#3 | |
#4 | |
if i only had a crashy... |
![]() Drives: 2010 sedan Join Date: Sep 2010
easy. make a light bar that pokes through the upper grill mesh and bolts into the steel crash bumper behind the plastic bumper cover. like this http://web.mac.com/jonnieoh/My_MINI_...ts_How-To.html only you can do it out the top grill and not the lower one. lucky for us, the lights wont interfere with the hood opening like some cars.
or, if you want real lighting, mount this in the upper grill http://www.rhinopartsandperformance....-LED-LIGHT.htm and you wont have any problems with seeing. |
| Question about lights | kaymm | General Yaris / Vitz Discussion | 4 | 04-20-2020 10:10 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 02:15 AM |
| Tinting lights & windows pricing | wiirenet | Cosmetic Modifications (Exterior/Interior) | 15 | 03-22-2009 01:09 AM |
| Bad Driving Techniques | Altitude | General Yaris / Vitz Discussion | 10 | 02-10-2009 06:26 PM |
