![]() Drives: 1.0 vvti 2001 Join Date: May 2009
misfire on no 1 cylinder
Since I bought this 1.0 01 car, the engine management light has been on.
Diagnosed on basic machine as misfire on no 1 cylinder. Checked coil which is fine. New plugs fitted and currently trying injector cleaner in fuel. Wonder if its a sticky valve. Idle is rough and doesn't pull away cleanly. Its fine and smooth above around 1500 rpm. I'm a bit lost as to what to do next apart from expensive trip to main dealer! |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
If its got a check engine light on then it should be throwing a code to the OBD11 computer ,plug in a code reader and see what code is showing up.
not sure how you know its the No.1 cyl giving problems but if you've changed Coil,plug wire and plug it may not be the problem,a bad valve would either show some smoke blowby through the exhaust or oil contamination of the plug or it would be making some kind of noise. |
missfire code can also mean it's not firing at all. Upon a cylinder not working, IDLE will be rough, car will lack power and gas consumption will raise.
that's all i can tell.. i guess.. |
Parallel Parking Pro
Isn't the 1 litre a 3 cylinder engine? If it is, you're running on two cylinders...
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#5 | |
looks like the 1SZ-FE is a 4cyl engine!
Yes you're right, its a 4 cylinder - I got it mixed up with the 1 litre the Toyota Aygo has!
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
hey, how about checking your valve and lifter lash....it's on the hood. you need a feeler gauge.
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Do a compression test first. Also, The coil may look OK and have the specified impedance but still be bad due to dielectric breakdown. Luck on this one, mate.
map sensor output would be a good place to get a better idea of whats causing a misfire. if only one cyl. is misfiring... fuel psi/ clogged injectors and egr port clogging are unlikely but not impossible, however ignition side issues (coil pack/plug) or vacuum (bent valves) issue could be a more likely cause. there must be a diag troubleshooting chart for misfire on cylinder 1 in the service repair manual. if not check injectors, swap cyl 1 with cyl 2 and see if the misfire switches cylinders as well. do the same with the coil packs and spark plugs. those are some simple quick checks. then try a leakdown test on the misfireing cylinder see if its out of spec. good luck!
07 Yaris LB 5spd AE86 Corolla GTS 5spd http://microimage.ning.com/ http://www.microimageonline.com/store.html |
| Post pics of cylinder head (engine) covers here | joelitton | Cosmetic Modifications (Exterior/Interior) | 157 | 08-02-2017 11:36 AM |
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
| Misfire and engine light | Gazdaman | DIY / Maintenance / Service | 5 | 01-03-2009 09:20 PM |
| DIY Hood Cylinder | churp | Cosmetic Modifications (Exterior/Interior) | 46 | 06-25-2007 05:46 AM |
| Canada Only - Maybe a $1000 enviro rebate on Yaris> | MDF | New YARIS Purchase Forum | 45 | 05-01-2007 08:17 PM |
