Old 05-22-2009, 11:17 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
installing Penguin Garage rear hub spacers!
www.penguingarage.com
DIY instructions for Penguin Garage rear Hub Spacers:
tools required:
~ your wheel removal tools
~ jack and jackstand
~ Hammer
~ small Flat headed screwdriver (ABS-Equipped only)
~ 14MM socket and extension
~ 10MM Allen key (socket preferred for torque wrench)
~ Torque wrench (not required, but recommended)
Step 1: support car with jacking device of your choice. Remove wheel
Step 2: remove rear drum. remember to NOT set your emergency brake! :) tapping with a hammer helps with the drum removal process
Step 3: locate the hub bolts. use a 14mm socket to remove these 4 bolts
Step 4: remove the rear hub/brake assembly. if you are ABS equipped, you'll need a small flat-head screw driver to release the wheel sensor plug before removal of the hub
use the supplied grease (clear baggie with red grease inside) to lightly coat the mounting surfaces of each spacer. doesn't have to be THICK, just enough to discourage corrosion.
Step 5: insert one supplied bolt thru the hub assembly and slip the spacer over the bolt. this will make re-aligning the hub easier when bolting the hub back to the axle. tighten the hub bolts in a diagonal pattern, torque the new bolts to 80 lb/ft (for those of you who are not torque wrench-equipped, TIGHT). reinstall brake drum, wheel, and set the car down. you're now Penguin Equipped!
Old 05-23-2009, 12:05 AM   #2
supmet
Drives: 2007 4 Door Yaris
wow, even easier than I thought - I was expecting to have to disconnect the brake line and bleed the brakes after.
Old 05-23-2009, 12:12 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
no sir :) on the scion xD it may be recommended to loosen the e-brake cable bracket, but today i found that you don't need to with the yaris. just a little bit of elbow strength and you're back where you started, only wider.
fyi this was a 13mm spacer install :)
Old 05-23-2009, 12:37 AM   #4
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Dam thats a sick car!!!
Its a Chao!!!
Old 05-23-2009, 12:40 AM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
hah! yes it is! by the way i have the muffler delete pix on my memory card. pending a few quotes, i'm confident we can provide a product to penguin garage that they can sell
Old 05-23-2009, 01:51 AM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Thanks for the writeup/pics! Can't wait to do this mod.
Old 05-23-2009, 09:06 AM   #7
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
any before and after shots.. good job by the way...im definetely getting this but awaitng for new rims..
Old 05-24-2009, 03:23 PM   #8
Penguin Garage
Penguin Garage's Avatar
Drives: Yaris
Thanks for the great writeup Tamago.
Here is the "after" of the 13mm's installed on a sweet Blue Yaris!
I'll see if I can grab some before photos.
Penguin Garage is offline   Reply With Quote
Old 05-25-2009, 09:25 AM   #9
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Badass. I look forward to your long term review!
Old 05-25-2009, 10:59 AM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
i've had hub spacers on my scion for 5 years. my review is that they're a necessary mod with no downsides whatsoever :)
Old 05-25-2009, 12:07 PM   #11
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
I have a set as well I'm really glad we got them, i'm actually thinking of upgrading to the new 13mm's instead of my current 10mm's
Russelt3hPirate is offline   Reply With Quote
Old 05-25-2009, 11:09 AM   #12
marcus
toyota
marcus's Avatar
so if i do 13mm.. can i still fit +40 with 195/50/16 on the back without rubbing even if its loaded..when loaded or just 2 people on back the tires gets tucked in the fenders.
Old 05-25-2009, 12:14 PM   #13
Russelt3hPirate
l33t3st Asshole
I'd wait till Tamago comes back to confirm but according to my calcs, you'd be fine at 13mm. Although a 10mm would give you a little extra comfort room and still look great.
Old 05-25-2009, 12:33 PM   #14
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
nicely done
Old 05-25-2009, 12:35 PM   #15
marcus
toyota
marcus's Avatar
ok thanks..but would 3 mm make a big difference..seems so small of a difference though..
Old 05-25-2009, 12:48 PM   #16
Russelt3hPirate
l33t3st Asshole
it wouldn't make a big difference, 3mm is a lot for looks though.
if you're worried about rubbing I'd do the 10mm, if you want the most aggressive look go with the 13mm.
are your wheels 7" wide?
Old 05-26-2009, 09:26 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
added a blurb about grease. first sets of spacers DID NOT ship with grease as my supplier was on the lam. any water-repelling lubricant should work fine
Old 05-26-2009, 10:36 PM   #18
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Did my install today in about an hour.
Driver's side was easy, but passenger side was a little more of a pain. Drum did NOT want to come off.
Also, Tamago did you notice the tightness in the lower brake line when you didn the install on Enth's? My driver side was tight, but passenger side was damn near impossible to get the holes to line up because of how tight the brake line was, it had no more slack, lol.
Also, the ABS sensors wires were a pain in the ass.
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Gauging interest on hub spacers for the yaris Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 61 05-22-2009 02:18 PM
Rear Spacers... (Who sells them?) Saggio General Yaris / Vitz Discussion 6 02-06-2009 08:40 AM
Installing a rear window defroster trn9 DIY / Maintenance / Service 0 01-06-2009 02:56 AM
