![]() Drives: 2007 Toyota Yaris Hatchback Join Date: May 2009
Front/Rear Brake Wear
It's been a while since I last checked my brakes so I decided to check them today since I was already in need of changing my oil.
Note: My car just recently hit 70k miles. I drive freeways to school, stop and go in morning traffic. I deliver pizzas so there's also a lot of stop and go there too. I don't normally drive fast and I usually do not hit my brakes really hard (I usually stop gradually). I inspected the front brake pads and was amazed at how little wear there was. In fact, they still look fairly new. ![]() For so many miles, I had to think that my rear brakes were taking more of the stopping than my fronts. So I decided to check my rear brakes. I don't know much about rear brakes but I took some pictures and was hoping someone could tell me if they look normal, need to be replaced, etc. ![]() ![]() ![]() ![]() Sorry, that was the only ruler I could find. The brake drum seems fine with normal wear but I should probably get that inspected. There was no rust on the inside and it appears to have full contact with the shoes. Similarly, the front rotors. I cannot recall if I've ever had the rear brakes adjusted. Any ideas? |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
All looks good. Should be good for quite some time.
unless i'm missing something, but the last pic, on the left side... seems the shoes are completely worn?
SIPNDEW
i dont think the shoes pad surface covers the entire plate. if i remember correctly looking at mine, it looked the same way
Whoa, yeah that looks wierd, but most likely normal.
I noticed on mine the other day that it was a but short, but no where near that length, and I noticed cracking and chipping at the edges. I also have now 51,000miles on my car and my brakes up front look NEW, but the rear is showing its time is up, and the sqeaking from the drums says it all. |
rear brakes are taking a little more abuse than normal Make sure they are adjusted properly so you get even wear
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
ya...all you auto guys be sure and hit your parking brake at least 3 times a week...that'll keep them adjusted. and u manual guys shouldnt have a problem unless you put it in gear when u park
![]() Drives: 2009 Yaris, 2-door liftback Join Date: Mar 2009
I always use my ebrake when parking
Drives: 2007 4 Door Yaris Join Date: Jan 2009
20 bucks says you work at the papa johns on foothill, not the one on carnelian. Above the 210 will eat your pads. Either way, your pads are lasting WAY longer than mine did..
Cool. Thanks for all the responses. I just wasn't sure what to think since the brakes on both of my previous cars were gone by 50k.
And about the last picture, it is correct that the shoe pad does not cover the entire plate. I'll make sure I have the rears adjusted the next time I'm at the shop. |
#11 | |
How many clicks @ the e-brake? If around 5 clicks you should be about right on your shoe adjustment. If your fluid is turning dark that's something I'd consider having flushed. Looks like it'll be a while before you need new pads or shoes, and if the fluid is dirty now flushing might save you the need to replace your rear wheel cylinders during shoe replacement. |
i thought the pads are not THAT short from the top of the drum assembly...
and i'm not that +1 on the parking brake for auto adjustment. Mine clicked 10-15 times before i adjusted them.. so it pretty much says all how much they auto adjust lol. |
I always adjust my rear brakes by hand. About 11 clicks per side last time. I do it about every 6 months.
I think the self adjusting feature on this car is a joke......
Never take eyes off opponent - Bruce Lee |
#14 |
Self adjusting is just that.
Like at the gas station, you have self served. It doesnt mean someone or something will put the gas in for you, it means get out, open the gas tank door, and pour in the gas yourself. Same applies for this dumb drum system. Open them up, and adjust them your-SELF! |
#15 |
I guess I'm just lucky enough to have a Toyota that self-adjusts the rear brakes as well as my uncle's '94 Chevy C1500...5 clicks at the e-brake when new, 5-clicks at the e-brake 15 months later
...or maybe it's because I'm the only one that uses the e-brake when parking and ever hits the brakes when I'm backing out of the garage
#16 |
I use my e-brake almost all the time when I park. It's just habit. Just checked and it's currently 5 clicks for the e-brake. When I was inspecting the rear brakes yesterday, I attempted to adjust them myself...7 clicks each side. It seemed a little more firm when applying brakes but it could just be my imagination.
I'm not sure how many clicks it was for the e-brake before I adjusted the rear brakes though. Usually, when I bring my cars into the dealership to get serviced, my e-brake barely comes up. After several months, it eventually it comes up all the way. Maybe Im pulling on it too hard? Not sure. Fluid looks normal right now. |
#17 |
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles" Join Date: Apr 2009
So how many clicks does it take to get to the center of. . . . . whoops . . . wrong forum.
+1 on the whole using the "park"ing brake when I "park". Seems very re-donk-u-lus not to, ever since one of my friends has his parked car hit from behind. He had an auto, did not put the e-brake on, and when his car was hit, it broke the parking pin thing, and pushed his car into someone else's. That "someone else" filed an insurance claim against him!
2009 Absolutely Red LB. "Bubbles" |
#18 | |
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| DIY For radios that require attaching a wire to parking brake | Slick | DIY / Maintenance / Service | 0 | 04-16-2009 08:14 PM |
| BIG(GER)TM BRAKE KIT | Vanderkitten | Performance Modifications | 23 | 01-04-2009 07:16 PM |
