Old 06-02-2009, 03:01 PM   #1
mrbond
mrbond's Avatar
For those who have the rear disc brake conversion
After reading a recent thread about fabricating one's own bracket to accomodate a larger brake setup that wasn't meant for the Yaris. It got me to thinking about the rear disc brake conversion, and questions came out of that.
First - the rear disc included in the kit. Are the internals of that disc the same as the internals of a front disc?
Second - what brake pads would be compatible with it?
Thanks to whoever knows the answers!
- A Toyota Yaris
- A whut Yaris?
Old 06-02-2009, 03:16 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Rotor is probally made of simular material but its not going to be vented. Most rear rotors are not as they do not take the abuse that front rotors do. Weight of the motor is in the front and when you brake the car dips down thus the front brakes take probally about 80 percent of the braking force which is why u typically go through 2 -3 front brake jobs to every rear brake job depending on your driving style and area ie lots of hills compared to normal commute.
Second i think u can only get the brake pads that come with the kit as no aftermarket manufacture is going to mass produce something that is going to have extremly low sales.
Old 06-02-2009, 06:18 PM   #3
Penguin Garage
Penguin Garage's Avatar
Drives: Yaris
it depends, alot of manufactures share similar size brake calipers/pads.
Using the same caliper for different applications allows economies of scale for both calipers and the required pads.
alot of the brake pad manufactures sell replacement pads for nearly all popular bbk and stock calipers.
Penguin Garage is offline   Reply With Quote
Old 06-02-2009, 06:42 PM   #4
why not ask the vendor - me?
The rear calipers and pads are made in Thailand. I carry replacement pads, and CarboTech will make pads for these calipers if I (1) run out or (2) someone wants something special.
I'm not sure of the exact rotor material, but I'm not sure what you mean by the "internals of the disc". The construction is different, because it retains an e-brake shoe inside. So, when you install it, you have a place to attach the e-brake cable.
Old 06-05-2009, 11:43 AM   #5
kngrsll
Apexing Egg!!
kngrsll's Avatar
thats really cool that it retains the E brake function. Now what about brake balance? does it do anything to change the front to rear balance? i would think it would have to shift it to the rear a little, which may not be bad.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-05-2009, 01:58 PM   #6
Brian
Brian's Avatar
I felt a slight increase in braking after I installed the rear discs.
Old 06-05-2009, 02:56 PM   #7
kngrsll
Apexing Egg!!
kngrsll's Avatar
i could imagine... the rear drums are pretty pathetic.
Old 06-02-2009, 08:32 PM   #8
mrbond
mrbond's Avatar
Yeah, by internals I meant the construction.
See, after reading this one thread I got the idea to make a big brake kit out of your 320mm rotor, Evo calipers (with a remade relocation bracket), and using Evo rear calipers with the rear disc conversion in place of the calipers that come with it. However, after researching a bit, the rear Evo calipers require a larger rear disc, thus making my original question kinda useless :/
- A Toyota Yaris
- A whut Yaris?
Old 06-02-2009, 08:41 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
not to mention 5X114.3
Old 06-02-2009, 08:42 PM   #10
mrbond
mrbond's Avatar
Well, no, I factored that in. I meant using front rotors for the Yaris on the rear. The bolt pattern would not change, otherwise I'd need new hubs, new wheels, etc which would be a huge pain in the ass to do. If you think about it, it's not that hard of a deal.
- A Toyota Yaris
- A whut Yaris?
Old 06-02-2009, 08:44 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
why not a honda civic BBK to build off of? MR2 MKI? MR2 Spyder?
Old 06-02-2009, 08:50 PM   #12
mrbond
mrbond's Avatar
I looked up civic BBKs, and the cheapest things I found were by Wilwood, and those were about a grand. I figure, with $430 for the big rotors from Garm, and another $300 for Brembo calipers off an Evo, I'd make a pretty competent Brembo brake kit for under a grand (after rebuilding the calipers and adding stainless steel lines). I'd much rather do this than keep small rotors and buy those crappy caliper covers. I like Brembo - the performance they offer and also the looks. Can't get a Brembo kit made specifically for the Yaris, see ;)
- A Toyota Yaris
- A whut Yaris?
Old 06-02-2009, 09:00 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
so what is YOUR reason for big brakes then?
Old 06-02-2009, 09:14 PM   #14
mrbond
mrbond's Avatar
To say that I have Brembos...without having to pay almost 3 grand for a full Brembo kit.
- A Toyota Yaris
- A whut Yaris?
Old 06-02-2009, 09:18 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
lol
Old 06-02-2009, 09:19 PM   #16
mrbond
mrbond's Avatar
^ hey, both you and I have heard of waaaaay worse reasons for bigger things lol
- A Toyota Yaris
- A whut Yaris?
Old 06-02-2009, 09:49 PM   #17
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
i really like that idea and t will give you looks and brake power, let me know how if you do it
cruz-gsr is offline   Reply With Quote
Old 06-02-2009, 09:52 PM   #18
mrbond
mrbond's Avatar
^ for sure. It'll be sometime around the beginning of next month, since it'll be a while till I get enough for the larger rotors. The calipers have been ordered already.
- A Toyota Yaris
- A whut Yaris?
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
rear disc conversion vten Performance Modifications 56 06-17-2009 05:34 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
Rear disc brake conversion installed Brian Performance Modifications 49 03-04-2009 11:45 PM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
