![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
What causes wheel gaps to be uneven?
I was checking my wheel gaps today to see how things are since the lowering springs and shocks have been installed for a while now. It seems like two of the gaps were much shorter in distance as compared to the others being a bit bigger in gap size. I can't imagine any reason why it would be that way since they've had time to settle and the air pressure is even in all tires. I did hit a monster sized puthole the other day but as far as I can tell it didn't throw the alignment off at all so I have no idea what could be the reason it's uneven. My only guess is maybe just the pavement has to be completely smooth and flat to get an "even" look all the way around?
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Which sides are you comparing? Front to back, or left to right?
If front to back, then the rear gap usually is smaller in all cars because it doesn't arch as high as the front (from what I've always seen).
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
I'm comparing left to right. I noticed that the one side that is lower, the opposite side in the rear is also lower at the same time. That's what's leading me to believe it's just the pavement not being even or whatnot. The car itself looks perfectly flat and level, not funky leaning or angles.
More weight of the vehicl eis on that side such as battery.
As mentioned, the battery and intake are on the left side, as well as the driver and steering parts. My sub is also on the left side, so I wouldn't be surprise if my left side is a bit lower.
Joey
That and driving without passengers adds more weight to the left. I would take right turns much more slowly if I were you lol
| Official YARIS Wheel & Tire Guide | Black Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 404 | 06-02-2026 01:19 PM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| Steering Wheel Issue. | Twistoffate0817 | General Yaris / Vitz Discussion | 8 | 01-31-2009 07:38 PM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
| Yaris wheel rate ratio (06+) ? | dsc_pat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 07-05-2007 05:43 PM |
