Old 07-29-2009, 08:41 AM   #1
TRDMarty
Continuous Starter!! WTF!!!
I have a 2008 LiftBack and periodically when I turn the key to the ''CRANK'' position to start the engine, it continues to keep cranking. I've even got out of the car and stood there looking at it while it continues cranking. The only way to stop it is to turn the key to the off position. Try a re-start and it works OK. Yes, I have taken it to the dealer but all they can tell me is that they cannot replace anything related to the starting system unless they can make the same scenario happen. No such luck. They want me to leave my car with them for a couple of months, HUMMM, make monthly car payments and DON'T get to drive my car, I dont think so.
Anyone have a same starter issue???
Marty
Old 07-29-2009, 08:51 AM   #2
Cutie Pie #2
Drives: 2014 Honda CR-V LX
That has happened about 3 times since I've had my car, dealer said couldn't find anything wrong with anything each time I took car in. I just turn it off when it does it and restart. Mine has only done it during warmer weather.
Cutie Pie #2 is offline   Reply With Quote
Old 07-29-2009, 09:00 AM   #3
bronsin
bronsin's Avatar
On my Yaris the engine will crank even after releasing the key from the crank position back to the on position. Once it starts it stops cranking. It seems to be some sort of normal function. Is that what yours is doing?
Old 07-29-2009, 09:10 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
sounds like a bad starter solenoid or relay?
Old 07-29-2009, 09:39 AM   #5
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Its a bump starter. Its completely normal. How does your car not start when its just cranking?
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 07-29-2009, 10:01 AM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
guys.. and girls.. please turn it to "ON" position for at least 5 secs before going to "crank"
this will solve your "unstopping" cranking... and the car not starting up.
Old 07-29-2009, 05:30 PM   #7
2009Toyotoad
Drives: 2009 Yaris 3dr
I was guessing weak battery too! Solenoid isn't disengaging correctly because the starter gear is not going through the full length of travel. Is the quick fix to replace the starter return spring? Or is it just cheaper to freshen up the battery with clean contacts, and a good charge and load test?
2009Toyotoad is offline   Reply With Quote
Old 07-29-2009, 05:39 PM   #8
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
hadn't heard the 5 secong rule before. But I have had the problem a couple of times and just stomp the gas pedal (Clutch engaded) and it stops crankin.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 07-29-2009, 06:44 PM   #9
LEGATO``
LEGATO``'s Avatar
+1
this is what i always to regardless of what car i am driving
it kinda just, i guess, recirculates the batt to flow, if you know what i mean
Project LEGATO
Old 07-29-2009, 10:02 AM   #10
Snyprwlf47
The Martian
Snyprwlf47's Avatar
I kinda like to just tap the key and the car starts itself
Old 07-29-2009, 10:35 AM   #11
Does your car have the engine immobilizer? If so, it might be having trouble reading the transponder key.
When I installed my remote starter, my key bypass module was shipped separately, so I initially installed the remote start without out it. In testing the remote start, If I hit the remote start button, without having a key by the keyswitch, the starter would continually crank until I aborted the remote start.
Old 07-29-2009, 07:02 PM   #12
TRDMarty
I have tried the 3 to 5 second method and still occasionally it sticks while in crank mode.
From reading some of your replies on this subject it appears that I'm not alone with this sticky start issue. Again, the engine does not start and run while it's decided to do the auto-crank. I noticed this when I got out and stood there looking at it saying WTF?? while it's just cranking. And yes,that was the ONLY time I got out to look at it while doing this & it was just a couple of seconds. Now when it happens I just turn it off and restart with no problems.
Old 07-29-2009, 07:07 PM   #13
yaris prime
Yes- I fit in it.
yaris prime's Avatar
Drives: 2007 Yaris liftback, MT
It's called the cranking hold, and it is a feature (although an annoying one) of the car. Mine was acting funny while holding the key at crank like a normal car so I looked in the manual and found it under "starting." You simply turn the key to crank for a second and then it cranks it until it starts- no need to hold it in the cranking position. Now, if it doesn't start, that is another matter.
I'm surprised it doesn't have a pull-start !
yaris prime is offline   Reply With Quote
Old 07-29-2009, 09:18 PM   #14
supmet
Drives: 2007 4 Door Yaris
I'm at 73000 miles, and never have to wait at "acc" or "on" before cranking it over.
Whether or not waiting 5 seconds fixes the problem or not, there is still an underlying problem, or something not working as it was intended.
Tell your dealer to fix it or you will go out into the parking lot and turn the car off and on until 1) it repeats the symptoms, or 2) the starter dies and the dealer will be replacing it under warranty.
Old 07-29-2009, 10:18 PM   #15
Besides the engine immobilizer thing that I mentioned above (of which I take it those of you that have experienced the issue don't have), there are numerous ECM related failure modes which could cause this. Most of these failure modes could be intermittent and could easily be thermally induced.
Old 07-30-2009, 07:22 AM   #16
highwaypass
Captain Slow
Drives: '08 1.5 hatchback
just turn the key to off position then start to crank it up again.
It recently happens in my hatchback,so far no problem at all
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA
highwaypass is offline   Reply With Quote
Old 03-26-2012, 09:02 PM   #17
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I know this is an OLD ASS THREAD, but I have the same "endless" crank scenario every 50 or so starts....any new updates on this problem?
-Type 07 FFL-
My odometer 03/11
Old 03-27-2012, 08:19 AM   #18
TRDMarty
I'm the original guy that listed this thread.
Answer to your question = NO
My car still does the auto-crank from time to time.
I tried walking backwards to the car before attempting a start.
Tried skipping around the car 2 or 3 times.
Tried starting it with my left hand instead of my right hand.
Took the spare change from my right pocket and put it in my left pocket, then tried.
(just kidding)
But yes, it still auto-cranks every month or two and I still say = WTF!!!!
remote starter, instaled but cant get tach sig? karl53913 DIY / Maintenance / Service 8 11-26-2008 10:40 AM
Remote Car Starter KittenRD Fuel Economy Forum 6 11-08-2008 11:53 AM
Starter problem wormley DIY / Maintenance / Service 2 10-29-2008 09:56 AM
starter kill & horn help spechuy DIY / Maintenance / Service 0 10-20-2008 01:30 PM
Starter dragging YarisTom73 DIY / Maintenance / Service 5 08-27-2007 12:11 PM
