Old 11-22-2008, 09:39 AM   #1
karl53913
Drives: 2008 yaris lb
remote starter, instaled but cant get tach sig?
help. I installed a new remote starter, and from tach install forum it shows tach wire on far left of service plug? mine has no wires on that side? where else can I get tach info for my starter?
any help greatly appretiated.
karl53913 is offline   Reply With Quote
Old 11-22-2008, 02:46 PM   #2
karl53913
Smile answered by reseach
reviewed the 2007 factory wiring diagram. shows tach wire as light green (as stated in tach install thread?), and connects to #9 spot in the data link connector.rechecked my #9 wire, it is light orange? hooked tach to it and worked?
so my wiring for a 2008 yaris HB is as follows:
tach wire from remote starter connects to light orange wire #9 spot
starter wire from remote connects to small black wire at ignition switch
Acc. wire from remote connects to green wire at ignition
ignition wire from remote connects to pink wire at ignition
red wire from remote goes to fuse box constant power
Old 11-22-2008, 06:02 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Yep, 2007 is green, 2008 is orange...
Old 11-23-2008, 01:40 AM   #4
Revsson
What about the 2009 ??
Old 11-23-2008, 02:48 PM   #5
PetersRedYaris
You should check yours out and post it here.
Old 11-24-2008, 09:00 PM   #6
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
what type of remote start you have cause i always run mine using voltage sense instead of using tach
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 11-25-2008, 03:14 AM   #7
Revsson
I guess I should.
Old 11-25-2008, 08:32 AM   #8
Check this out from my remote starter install - 09 is the same as 08
http://www.yarisworld.com/forums/sho...?t=9570&page=3
Interesting note though, on 07 using the green wire. That explains why the documentation that I had found indicated the green. I initially used the tach wire going to the TPWS module behind the passenger glove box, but then ended up finding the correct tach wire on the obdii plug as shown in the picture above.
Old 11-26-2008, 10:40 AM   #9
Revsson
Thanks CTScott
You knew I was a little too lazy to go poke my head under the dash.
I bow to you for reading wiring diagrams and posting pics!!
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
Remote Car Starter KittenRD Fuel Economy Forum 6 11-08-2008 11:53 AM
