![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
anyone got fogs on 09?
im looking to doing up fogs on my 09, iv seen lots of pre 09s with them, anyone have them on their 09? (i know what i need to get, just i want to see pics of them installed)
im also wondering what would look better on my Meteorite Metallic, clear (yellow bulb)/(hid so it wont be yellow bulb) or yellow lens. Im not sure if id like seeing a yellow bulb all reflected on the housing when its not on.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
Here you go:
'09 Yaris with fogs (clear lens) and Nokya Hyper Yellow (2500K) halogens.
#3 | |
Scrubble with a poke.
Drives: 2009 Yaris LB Join Date: Jul 2009
What does Garms switch look like installed? I want to get a set too.
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen |
It looks like the OEM center console switch or any of the other aftermarket kit switches. I don't have a pic of it, as I decided to use my own. I wanted the switch to be next to the dimmer rheostat, instead of in the center console.
The for switch isnt on the stalk from the factory? Its a seperate button near say the Aux port?
Oh okay! Sounds good to me then!
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
Can't recommend the new wiper switch enough. It's OE and lights indicate the fogs are on in the dash (car pre-wired). Well worth the money. Removing the wheel is super easy as well thanks to write-up here on YarisWorld.
how much more does that run? I mean if you buy garms kit and then the stalk? I would prefer them on the stalk too but for 100 i wont complain especially if its still almost oem.
#11 | |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
Headlight combo switch with fog light control- $92.14 (TRDSparks; they had a cheaper combo switch for around $70, but no one could confirm for sure whether it worked on the '09, so I got this one) 2009 shrouds- $37.58 (TRDSparks) Micro Image Fog Light Kit- $99.00 Total- $228.72 for OEM fog lights Of course, since I was pulling the steering wheel anyway, I had to install the OEM cruise control and swap for a leather steering wheel, which jacked the $$$ up quite a bit more
I put the oe light stalk on.its easy... my issue I have is I did the switch, relay, and fuse but I can't seem to find he power in that relay box behind the LS headlight. im sure I just have something not quite right
#13 | |
Fog Power.jpg |
#14 |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
I have the factory ones...
#15 |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Anyone make a complete fog light kit yet for the '09s? I don't want to buy an '07/'08 kit and then have to buy the bezels for the '09.
#16 | |
#17 |
i guess we will need to wait a little longer...same goes for the head and tail lights.
#18 |
Does his kit come with the '09 fog light shrouds?
Edit: Just checked. They don't. |
| Fogs with highbeams | rhino5 | Cosmetic Modifications (Exterior/Interior) | 20 | 06-30-2009 01:43 AM |
| fogs + better pictures | TickleTimeTim | Cosmetic Modifications (Exterior/Interior) | 12 | 05-15-2009 08:57 PM |
| Smoked Fogs | TickleTimeTim | Cosmetic Modifications (Exterior/Interior) | 17 | 02-22-2009 01:20 AM |
| Question about fogs | custom Lftback | General Yaris / Vitz Discussion | 4 | 01-29-2009 11:11 PM |
| HID KIT and FOGS | falkor_99 | Photo-Video-Media Gallery | 31 | 07-05-2007 10:49 AM |
