Old 06-20-2009, 08:04 PM   #1
rhino5
Drives: '08 hatchback, '90 325i 'e30'
Fogs with highbeams
I'm rolling around the idea of putting 3000k HID fogs in, but I'd like them to be lit with the highbeams.
I did a search and found this:
http://www.yarisworld.com/forums/sho...light=foglight
I have an 08 LB S-model with stock fogs.
Is there a relay I can jump so that when I turn my fogs on...they're on...and when I turn them off...they're off rather than them being on with low when the switch is on and the fog lights off when the highbeams are engaged?
My reasoning would be I work 3rd shift and drive at night mostly, so I'd like more visibility, but I'd also like the HID's to be on from the time I switch my foglights on until I turn them off or turn off the car to prolong the life of the bulbs and also gain a little extra night vision while having the highs engaged.
Let me know of any ideas.
Thanks in advance.
rhino5 is offline   Reply With Quote
Old 06-21-2009, 12:39 AM   #2
rhino5
legal or not...I would put a vast sum of money on the number of times I've seen an SUV or a Jeep switch from Highbeam to Lowbeam and there were 4 lights before and after the switch....
Old 06-21-2009, 12:44 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
simply change where the foglight relay gets it's signal :)
Old 06-21-2009, 09:29 AM   #4
DerFlosser
DerFlosser's Avatar
Such as?
DerFlosser is offline   Reply With Quote
Old 06-21-2009, 10:36 AM   #5
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Why do you all have such difficulty seeing at night?
Old 06-21-2009, 10:37 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by DerFlosser View Post
Such as?
someone post a pic of the EWD and i'll draw it for you all
Old 06-28-2009, 11:47 AM   #7
rhino5
I work 3rd shift. This is my nightly commute:
http://maps.google.com/maps?f=d&sour...,1.056747&z=11
My current standing record is seeing 14 deer between Troy and Southport on rt. 14 (1 way). Just because I have comprehensive insurance, doesn't mean I want to use it.
Old 06-28-2009, 08:21 PM   #8
Jerkratt
Jerkratt's Avatar
ill take pictures tomorrow if u have day time running lights u take out the relay... and then take the foglight wire and insert into the relay harness to match colors but ill take pics to show where it goes.. once u do this u can turn ur fogs on and off as u please... just dont forget to turn them off when u get outta ur car
"It hurts more when its wet"
Old 06-28-2009, 08:31 PM   #9
1NZYaris1
1NZYaris1's Avatar
Thanks in advance.
Do you have a dash switch or a switch on your steering colum.
mine are wired too stay on with high beam .
Old 06-28-2009, 08:57 PM   #10
To make the fogs work with hi or lo beam with the OEM headlight stalk with the fog light switch, snip the orange wire going to pin 4 on the stalk connector, tape or wirenut them so they won't touch anything, and then ground pin 4 at the connector. Once you do that, the fogs will come on regardless of headlight mode.
Old 06-28-2009, 09:21 PM   #11
auxmike
auxmike's Avatar
Attachment 25362
Good lookin' out, CT!
Old 06-29-2009, 03:16 PM   #12
Jerkratt
Jerkratt's Avatar
yup thanks thats what i was going to take a picture of
Old 06-29-2009, 03:28 PM   #13
Split
Drives: 2008 Yaris Sedan
Exclamation
ive never understood why foglights need to b e off for highbeams to engage in automobiles.. seems to me when your highbeams are on, its extra important to have your fog-lights on as well so you can still see the ground directly infront of you.
Split is offline   Reply With Quote
Old 06-29-2009, 03:30 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
because fog lights are for FOG, and everyone knows you don't run your HIbeams in FOG lol
Old 06-29-2009, 04:06 PM   #15
Split
okay when i'm on a country road at night time, and i want maximum visibility, and there is NO fog.. why cant i use both if i want? Turning off the fog-lights when you use your highbeams makes no sense. un-educated drivers will most likely put their highbeams on anyway, and end up disabliting their foglights.
Old 06-29-2009, 04:27 PM   #16
my fogs stay on all the time, must be wire like CTScott's advice.
Old 06-29-2009, 04:45 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
exactly. every manufacturer in the WORLD does this.. you might as well complain because we're taught that cell phones should be turned off while flying
Old 06-29-2009, 05:17 PM   #18
1NZYaris1
1NZYaris1's Avatar
In New Zealand , they call them driveing lights if they
stay on with high beam . and fog loights if they turn off
fogs + better pictures TickleTimeTim Cosmetic Modifications (Exterior/Interior) 12 05-15-2009 08:57 PM
Smoked Fogs TickleTimeTim Cosmetic Modifications (Exterior/Interior) 17 02-22-2009 01:20 AM
Question about fogs custom Lftback General Yaris / Vitz Discussion 4 01-29-2009 11:11 PM
Chrome turn signal bulbs/yellow tint'd fog's blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 26 01-15-2009 12:05 AM
HID KIT and FOGS falkor_99 Photo-Video-Media Gallery 31 07-05-2007 10:49 AM
