Old 06-20-2009, 09:04 PM   #1
rhino5
Drives: '08 hatchback, '90 325i 'e30'
Fogs with highbeams
I'm rolling around the idea of putting 3000k HID fogs in, but I'd like them to be lit with the highbeams.
I did a search and found this:
http://www.yarisworld.com/forums/sho...light=foglight
I have an 08 LB S-model with stock fogs.
Is there a relay I can jump so that when I turn my fogs on...they're on...and when I turn them off...they're off rather than them being on with low when the switch is on and the fog lights off when the highbeams are engaged?
My reasoning would be I work 3rd shift and drive at night mostly, so I'd like more visibility, but I'd also like the HID's to be on from the time I switch my foglights on until I turn them off or turn off the car to prolong the life of the bulbs and also gain a little extra night vision while having the highs engaged.
Let me know of any ideas.
Thanks in advance.
rhino5 is offline   Reply With Quote
Old 06-21-2009, 01:39 AM   #2
rhino5
legal or not...I would put a vast sum of money on the number of times I've seen an SUV or a Jeep switch from Highbeam to Lowbeam and there were 4 lights before and after the switch....
Old 06-21-2009, 01:44 AM   #3
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
simply change where the foglight relay gets it's signal :)
Originally Posted by xnamerxx
you nailed it sir.
Old 06-21-2009, 10:29 AM   #4
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Such as?
DerFlosser is offline   Reply With Quote
Old 06-21-2009, 11:36 AM   #5
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Why do you all have such difficulty seeing at night?
Old 06-21-2009, 11:37 AM   #6
Tamago
Tamago's Avatar
Drives: ZZW30
Originally Posted by DerFlosser View Post
Such as?
someone post a pic of the EWD and i'll draw it for you all
you nailed it sir.
Old 06-28-2009, 12:47 PM   #7
rhino5
I work 3rd shift. This is my nightly commute:
http://maps.google.com/maps?f=d&sour...,1.056747&z=11
My current standing record is seeing 14 deer between Troy and Southport on rt. 14 (1 way). Just because I have comprehensive insurance, doesn't mean I want to use it.
Old 06-28-2009, 09:21 PM   #8
Jerkratt
Jerkratt's Avatar
ill take pictures tomorrow if u have day time running lights u take out the relay... and then take the foglight wire and insert into the relay harness to match colors but ill take pics to show where it goes.. once u do this u can turn ur fogs on and off as u please... just dont forget to turn them off when u get outta ur car
"It hurts more when its wet"
Old 06-28-2009, 09:31 PM   #9
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Thanks in advance.
Do you have a dash switch or a switch on your steering colum.
mine are wired too stay on with high beam .
Old 06-28-2009, 09:57 PM   #10
To make the fogs work with hi or lo beam with the OEM headlight stalk with the fog light switch, snip the orange wire going to pin 4 on the stalk connector, tape or wirenut them so they won't touch anything, and then ground pin 4 at the connector. Once you do that, the fogs will come on regardless of headlight mode.
Old 06-28-2009, 10:21 PM   #11
auxmike
auxmike's Avatar
Attachment 25362
Good lookin' out, CT!
Old 06-29-2009, 04:16 PM   #12
Jerkratt
Jerkratt's Avatar
yup thanks thats what i was going to take a picture of
Old 06-29-2009, 04:28 PM   #13
Split
Drives: 2008 Yaris Sedan
Exclamation
ive never understood why foglights need to b e off for highbeams to engage in automobiles.. seems to me when your highbeams are on, its extra important to have your fog-lights on as well so you can still see the ground directly infront of you.
Split is offline   Reply With Quote
Old 06-29-2009, 04:30 PM   #14
Tamago
Tamago's Avatar
Drives: ZZW30
because fog lights are for FOG, and everyone knows you don't run your HIbeams in FOG lol
you nailed it sir.
Old 06-29-2009, 05:06 PM   #15
Split
okay when i'm on a country road at night time, and i want maximum visibility, and there is NO fog.. why cant i use both if i want? Turning off the fog-lights when you use your highbeams makes no sense. un-educated drivers will most likely put their highbeams on anyway, and end up disabliting their foglights.
Old 06-29-2009, 05:27 PM   #16
my fogs stay on all the time, must be wire like CTScott's advice.
Old 06-29-2009, 05:45 PM   #17
Tamago
Tamago's Avatar
Drives: ZZW30
exactly. every manufacturer in the WORLD does this.. you might as well complain because we're taught that cell phones should be turned off while flying
you nailed it sir.
Old 06-29-2009, 06:17 PM   #18
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
In New Zealand , they call them driveing lights if they
stay on with high beam . and fog loights if they turn off
fogs + better pictures TickleTimeTim Cosmetic Modifications (Exterior/Interior) 12 05-15-2009 09:57 PM
Smoked Fogs TickleTimeTim Cosmetic Modifications (Exterior/Interior) 17 02-22-2009 02:20 AM
Question about fogs custom Lftback General Yaris / Vitz Discussion 4 01-30-2009 12:11 AM
Chrome turn signal bulbs/yellow tint'd fog's blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 26 01-15-2009 01:05 AM
HID KIT and FOGS falkor_99 Photo-Video-Media Gallery 31 07-05-2007 11:49 AM
