Old 09-07-2009, 08:18 PM   #1
o89canucks
Mechanic from hell
o89canucks's Avatar
Send a message via Yahoo to o89canucks
Front pad lifespan.
Was wondering what everyone else was seeing for average lifespan of the front brake pads on their cars. Just did the brakes this weekend at 38k miles and the front pads had minimal wear. Had a little bit of a shimmy in the front end so I still opted to get the rotors turned out, and reused the original factory pads. Just seemed to me to be a lot of mileage on those pads to be seeing that minimal amount of wear and wondering if this was normal for everyone else?
2007 Black Sand Toyota Yaris Sedan AT
2006 Sonic Blue Volvo S60R AWD 6MT
o89canucks is offline   Reply With Quote
Old 09-07-2009, 08:28 PM   #2
Brian
Brian's Avatar
Atleast 100k mi
Old 09-07-2009, 08:44 PM   #3
Kamikaze1987
Drives: 2007 Yaris Sedan S
I got 45k so far and was gonna change them this weekend but they still looked new and the rotors were perfect... my friend was amazed at how long the little pads lasted so far
Kamikaze1987 is offline   Reply With Quote
Old 09-07-2009, 08:54 PM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
i just changed mine at 65k and there was still pad left.
Old 09-07-2009, 10:29 PM   #5
I have like 42k, and I hear the indicator probably once a week. So I'm going to change them out and keep them as back ups since there should be some life in them still. Someone here told me that light braking is worse than heavy braking (I always did light braking).
Old 09-08-2009, 02:37 AM   #6
hafeez
Drives: 2007 Silver Toyota Yaris Sedan
I changed my pads this weekend and my car is at 80k right now. They had a little life left in them but i'll keep them as backups just in case. I was just wondering about the brake shoes though; how do you know when to change them?
hafeez is offline   Reply With Quote
Old 09-08-2009, 09:18 AM   #7
o89canucks
Mechanic from hell
o89canucks's Avatar
Pull off the rear drums and check shoe thickness. I would replace them if they have heavy stress cracks in them also. May as well do a clean and adjust while you are in there if the shoes don't need to be replaced.
Old 09-08-2009, 03:12 AM   #8
texkid
The one with cheese on it
Drives: '10 Corolla S
Reaching 30,000 miles and the mechanic says the shoes and pads still look new. Only had to turn the front rotors at about 20,000 miles (roughly).
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 09-08-2009, 12:29 PM   #9
supmet
Drives: 2007 4 Door Yaris
How can the pads look like new if you already had to turn your front rotors?
Old 09-08-2009, 12:36 PM   #10
o89canucks
Mechanic from hell
o89canucks's Avatar
The rotors can still get warped or glaze over without wearing much of the actual pad surface off.
Old 09-08-2009, 01:12 PM   #11
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
It's pretty much unheard of for disk brake rotors to actually warp. They get irregular patches of brake pad material deposited on the surface when used hard, especially if left with the pads in stationary contact with them while hot (i.e., the car's stopped for a bit after making a hard panic stop), and that makes the car shudder and pedal pulsate. Turning the rotor takes that off and gives a clean new surface, but they may also clean up with gentle normal use for a while, or with vigorous cleaning.
Old 09-08-2009, 02:14 PM   #12
1stToyota
1stToyota's Avatar
I don't know. I've turned lots of rotors over the years and what I see is runout and warpage (as in making two or three passes and still only removing metal at...let's say 12 o'clock, outboard, and 7 o'clock, inboard, for example). Now's the best time to see warped rotors because they're made so thin to save weight that they're usually below machine minimum (not discard thickness) after using up 1 set of pads.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 09-08-2009, 02:53 PM   #13
o89canucks
Mechanic from hell
o89canucks's Avatar
Who told you that pile of garbage???
I have resurfaced a lot of rotors and you can definetly tell that a rotor has lateral runout when it is on the brake lathe. Take a hot rotor and drive through a puddle or snow and it is like taking a hot pan off the stove and pouring cold water into it from the sink. I have even seen the lateral runout be so bad (most common in Mitsubishi's) that the steering wheel will have a shimmy while the brakes aren't applied.
The clamping force of the pads against the rotor is so stong that even if your theory of "brake pad deposits" had any truth to it, the "brake pad deposits" would be removed the very next time that you braked.
I guess flywheels never get hotspots in them either or warp out and never need to be resurfaced either if this theory were true?
Old 09-08-2009, 12:45 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
i got 50K miles out of my set, and that included autocrossing almost every weekend for 3 years.
my corolla i did 75K miles and still had plenty of pad.
and my 1988 pickup did 280Kmiles on it's first set
Old 09-08-2009, 02:17 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
what's this noise about rotors not warping? lol
Old 09-08-2009, 02:49 PM   #16
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
I have warped rotors and have turned warped rotors. It happens....
Old 09-09-2009, 06:07 PM   #17
Lafiro
Drives: 06 Yaris Sedan
I just got my car back from being at the shop for 5+ weeks... should make a thread on that one.
But finally driving my sedan and not my dads new SUV, makes me feel different, I love the cars handling again. But its sooo much lower lol. And no more leather anywhere.... and no more sunroof, and no more navi/XM ect...
ANYWAY!
So yes, my car has like what 60+k miles, and the pads look almost no different then from day one, and I usually stomp on them all the time, no slow stops for me. Maybe thats the difference? And although they stop the car just fine, I wish they would stop it faster, maybe thats the effects of these pads/rotors? The drums are fine as I just adjusted them a while ago. hmmmm I wonder what to do, but then again better not to fix something that isnt broken as they say.
Old 09-09-2009, 06:33 PM   #18
I think I also need to adjust my drums. I'll probably follow Jason's DIY on that.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Front spoiler koolerking Australia 3 07-20-2009 08:10 PM
Front bra for S model Sedan? N9QGS DIY / Maintenance / Service 2 06-27-2009 08:51 PM
