headlight aim
has anyone w/ a hatchback adjusted their headlight aim? how do you go about doing it...? i read the toyota manual online, but going an looking at the headlight, do i just spin the white, plastic screw, or do i need to get around the back of the adjuster and turn the scew in there?!?
ya, its totally different for the hatch....thanks though
Page LI-102 of the 2007 Service Manual has the procedure
#4 | |
![]() ![]() Drives: 2 Yaris Hatchbacks Join Date: Dec 2006
White screw. There is nothing additional to adjust at the rear of the lights.
For the US market, there doesn't seem to be any horizontal adjustment whatsoever, the horizontal adjuster screw is replaced with a snap-in post that is blank, and doesn't seem to be easily removable. Is Canada the same? The vertical screw is exposed, faces upwards, and is towards the inside (center of the car) of the headlamp assembly with the hood open. |
ya, just got back from doing it....its the white plastic screw...though counterclockwise seems to be down and clockwise is up
we'll see tonight if im still blinding people
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
Where can I buy a controller for controlling a luminance output of HID kits cause I already aim the headlight low as posible and put a black vinyl eyelid on the top, I still get flash by other cars.
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
My headlights were way too high when I bought the car. During the day I parked near the garage and turned the white screw on top. I watched the light drop an inch or so. At night I parked on a flat side street and made the final adjustment. The lights are now where I liked them. I didn't have to adjust the side ways shine, just the height.
Making a decision without following it with an action is still a fantasy. |
rice rocket
Drives: 05 Echo Join Date: Feb 2007
there are no controllers that can dim HID kit's for cars. Light going upwards is the bottom reflector, not the top, so the eyelids wouldn't help you. Does your bulb have a shield that blocks light from reflecting off the bottom reflector bowl?
My blulb has a shiled but its not enough.
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
Did you guys have to remove the headlight to get at the left side adjuster? I can't seem to get around the fusebox/intake.
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
Did you install low beam only or mechanical BI-xenon?
I installed the Bi-xenon’s and the shield blocks the bottom portion of the reflectors perfectly making some adjustments on my bulbs by stretching the spring that goes by the solenoid that way the bulb stays out more and the shield covers much better I also adjusted the height a little bit lower and it seems to be o.k. since no one complaints, and my headlights aren’t pointing to the floor either. |
| DIY Projector/HID (sedan) | Brian | DIY / Maintenance / Service | 145 | 02-05-2012 05:13 AM |
| Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison | CTScott | DIY / Maintenance / Service | 54 | 02-14-2011 09:58 AM |
| How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 03:12 AM |
| how the he77 do you aim the headlight!! | marcus | General Yaris / Vitz Discussion | 4 | 04-18-2007 07:58 PM |
| Headlight fog | elsteverino889 | Cosmetic Modifications (Exterior/Interior) | 2 | 03-28-2007 07:38 AM |
