Old 10-12-2009, 01:33 PM   #1
sex
sex's Avatar
Drives: 09 5DR
Page LI-102 of the 2007 Service Manual has the procedure
sex is offline   Reply With Quote
Old 10-12-2009, 01:37 PM   #2
has anyone w/ a hatchback adjusted their headlight aim? how do you go about doing it...? i read the toyota manual online, but going an looking at the headlight, do i just spin the white, plastic screw, or do i need to get around the back of the adjuster and turn the scew in there?!?
i read the manual, but looking at it in real life, is the vertical aim adjusted by the white plastic screw, or do i need to get at the back of that adjuster?
Old 10-12-2009, 03:10 PM   #3
Snappy
Drives: 2 Yaris Hatchbacks
White screw. There is nothing additional to adjust at the rear of the lights.
For the US market, there doesn't seem to be any horizontal adjustment whatsoever, the horizontal adjuster screw is replaced with a snap-in post that is blank, and doesn't seem to be easily removable. Is Canada the same? The vertical screw is exposed, faces upwards, and is towards the inside (center of the car) of the headlamp assembly with the hood open.
Snappy is offline   Reply With Quote
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 05:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 09:58 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 03:12 AM
how the he77 do you aim the headlight!! marcus General Yaris / Vitz Discussion 4 04-18-2007 07:58 PM
Headlight fog elsteverino889 Cosmetic Modifications (Exterior/Interior) 2 03-28-2007 07:38 AM
