Old 11-08-2009, 04:28 PM   #1
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
abysmal mileage!
how much impact do larger rims/tires have on MPG??
a couple months ago, i was getting ~35+ mpg city/highway with an un-modded stock engine, stock 15" wheels, no DIY cruise. now, i have 17" rims with obv wider tires, and the diy cruise. the engine is still stock. now, with these last couple tanks of gas, i've noticed HORRIBLE mpgs.. just last night, i got 24 mpg, highway. no weight in my car, just myself and my roommate.
i'm at a loss. i've even had the rims on there since july or so.. i understand that i'll take a hit pushing the wider tires, but geez!
the only other thing i can think of is that i used a fuel cleaner solution a couple tanks ago that i got from the dealership. could that really have had that much of an impact on my fuel economy??
any input is great.. i'm borderline nervous that this is here to stay! =\
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 11-08-2009, 05:44 PM   #2
yarswiss
Albino truck smasher
yarswiss's Avatar
Drives: '07 Yaris LB Auto
Larger tires will definitely affect your mileage. Since it is more weight and requires more energy per revolution, you will notice a hit on efficiency. If they are wider than the wheel well, they will affect the drag too.
I have used fuel cleaners before and never noticed any significant change in mpg whatsoever. They are probably good at doing just that, cleaning injectors and what not, but you probably can't tell in the numbers.
Not sure if your aftermarket cruise has anything to do with it. It may cause downshifts more often than necessary (in the auto) when under load. Try driving without it for a tank and see if that changes anything.
Basic concepts are: Less weight + slower speeds + good tires, alignment and maintenance = good fuel economy.
yarswiss is offline   Reply With Quote
Old 11-08-2009, 06:30 PM   #3
Kal-El
Kal-El's Avatar
They shouldn't make that much of a difference. Many members here have 17's and even 18's and still get 35+ mpg.
Old 11-08-2009, 06:52 PM   #4
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
+1 I run 18's and still get between 32 and 38 mpg.
A drop to 24mpg seems to indicate some sort of other problem (unless your new wheels are seriously heavy.)
Old 11-08-2009, 07:21 PM   #5
MadMax
MadMax's Avatar
No joking here, are you sure no one is siphoning gas from your Yaris?
Also, it could be "winter gas" as well. I noticed I went from a average of 37 MPG to 34 MPG on this last tank. The additional of ethanol does not help either; but your decrease is significantly higher than what I've seen (8-9%)...
Old 11-08-2009, 08:19 PM   #6
Kal-El
Kal-El's Avatar
Doesn't matter how heavy your wheels are, your not going to see a major drop in mileage. People have repeatedly reported getting similarly high mileage with a full load of passengers (800++lbs) as they do with just a driver in the car. In comparison, wheel weight is insignificant.
Old 11-08-2009, 08:52 PM   #7
enobmort42
First time DIYer
enobmort42's Avatar
yeah, that's what's so strange about this.. i drove from new york to florida, with a car FULL of my stuff, i mean, there wasn't a single free space at all. i even had socks stuffed in every opening i could, just to fit everything in there. that said, i still got between 33-37 mpg.
i've considered that, and even turned the sensitivity up on my car alarm! when i lived in new york, i noticed the difference in mileage from winter driving, but i'm in florida now. i haven't really altered my driving habits much, except i'm now taking advantage of the DFCO as much as possible! lol
i know that the wheels aren't lightweight. i'll try to take one off and weigh it, but the most accurate i'll be able to get will be my bathroom scale lol. they were cheap off craigslist, so that leads me to believe they aren't.
could it be the fact that i'm now at 65k miles and just, for the first time, used said fuel cleaner? could there be some clotting... idk, i'm just thinking aloud now lol.
thanks, everyone for the input! i appreciate it. i just filled the tank a few minutes ago and reset the trip, so hopefully i'll notice some sort of improvement...
Old 11-08-2009, 09:04 PM   #8
127.0.0.1
did the effective diameter of the wheels change...did you calibrate your odo to compensate ?
Old 11-09-2009, 01:27 AM   #9
enobmort42
First time DIYer
enobmort42's Avatar
hmm. if i remember correctly, the stock 15's were 185/65/15 and my current ones are 215/45/17. i think the overall diameter changed. is that what you meant? and no, i haven't calibrated my odo... how do i do that? and how would that effect my calculations?
Instead, I would advise checking your speedometer against a GPS. My wheels were put on at the dealership, so I don't know it the speedometer was recalibrated or not; but with my 17" rims my speedo is spot-on.
On my Jeep I found putting on 2" larger tires actually made my speedo more accurate. It was optimistic beforehand, as are most...
the best GPS i have is my phone, and i don't trust that, at all. plus, i've never found it to be truly accurate. then again, i've always considered my speedo to be "the standard" for my speed. would the dealership be able to calibrate it for me? i'll give the gps thing a try, first, though.
Another thing to try is to just unhook your battery for a night. Strange things can happen, and who knows what the fuel cleanser might've made your ecu think it saw. But you've had those wheels on for a while, and while heavier wheels will hurt fuel economy, it would be constant.
Have you changed anything else in your car recently? The fuel cleaner might have done something, but I would hope not that. Maybe something else could be wrong. What
did you have to hook the cruise to? The accelerator, or something else?
Also I remember your car got soaked recently, was it bad enough to have gotten into anything electrical?
yes, my interior got soaked beyond belief lol, but the extent of the damage was to both front seats and the carpet on the far left of the driver's area. the only electrical components that may have been affected were insulated wires running under the driver's side door sill panel thing. they were covered and insulated properly. i'll give the taking off the battery thing a try...
i haven't tried anything other than the diy-cruise, which i had pre-mpg drop, the wheels, which was pre-mpg drop, and the fuel cleanser, post-mpg drop.
Old 12-09-2009, 07:33 PM   #10
docB
Drives: '09 Yaris Sedan
Big wheels and tires are personal choice. If you like the look, let the mileage go. The heavier wheel and tire is not the only issue here. It is the larger distance from the center of rotation that is the big problem. It is easy to imagine a figure skater doing a spin. When arms and a leg are close to the body spin speed goes up. As the arms are put out away from the body, the skater slows. Same skater and weight, but slow spin when mass moves away from the spin axis. This is why a high wire walker carries a long pole. Performance can benefit from shorter side walls but only to a point. A larger overall diameter will make acceleration suffer. Less movement usually has the driver push on the gas more...less fuel economy. I'm looking to use 14" BBS wheels with a 185/70/14 tire for next summer. I 'll report milage at that time. Currently I have less than 4300 miles. I have averaged just over 40mpg with a one time high over 44 mpg.
I think the gps is way more accurate than an odometer. I just got a newer model and it recalculates much faster, aquires sats much faster and has better featuers than one I got for the wiffe two years ago.\
Madmax, an Altima I had '05 was off 2-3% on the odometer. I think it hurts the lease holder as the clock reads more miles than you drive.
doc
docB is offline   Reply With Quote
Old 11-08-2009, 09:18 PM   #11
MadMax
MadMax's Avatar
Old 12-09-2009, 08:59 PM   #12
nemelek
DWEED
nemelek's Avatar
You car also check the odometer against the highway mile markers.
Old 01-05-2010, 03:20 PM   #13
Sidicas
Drives: 2010 Toyota Yaris Hatchback
I agree.. If you can hold your speed for more than a couple minutes (straightaway on flat level surface), GPSs can be VERY accurate at determining your speed.
My Yaris speedo is showing about 2.5 MPH too high on stock 15" wheels..
Sidicas is offline   Reply With Quote
Old 11-08-2009, 10:18 PM   #14
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Colin Chapman disciple
Old 12-09-2009, 08:03 PM   #15
r3b3l
r3b3l's Avatar
Drives: 2010 Yaris 3dr liftback
I used some engine treatment in a bottle once in my motorcycle, it clogged the injectors bad and the engine seized. It was like someone chewed a whole pack of hubba bubba and put it in my engine. Had to have it scraped out at a mechanic garage. The same would happen to a car engine if too much was added.
r3b3l is offline   Reply With Quote
Old 01-06-2010, 12:21 AM   #16
supmet
Drives: 2007 4 Door Yaris
I realize this is an old thread, but going from heavy 215/45/17 from a 185/60/15, is an extra inch of diameter.
First, your speedo is off by about 3 miles at 65. Second, the extra inch of diameter pushes most of the tire weight out an extra inch, and the farther away from the center of a circle you are, the more rotational inertia it has, and the harder it is to turn the wheel. Not to mention the tires and rims are both heavier. Anyone telling you to expect over 30 mpg is lying or selling something.
Old 01-06-2010, 06:35 PM   #17
docB
The greater displacement of mass only makes its ugly face known during acceleration. Starting and stopping as in city traffic will make a bigger difference at the pumps than racking miles on the interstate.
Old 01-16-2010, 09:18 PM   #18
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Get your car serviced, change oil, air and oil filter. I recommend 32 psi front and 34 rear tyre pressure.If you take care of it you will probably see an improvement in mpg. Unless something wrong with your gauge.The Yaris needs to be freshened up to keep it happy.
-Mileage Thread- -Log your mileage, year, model, color, any problems here... Kal-El DIY / Maintenance / Service 322 07-20-2016 11:07 AM
2009 Yaris Mileage wornways Fuel Economy Forum 3 07-29-2009 12:42 PM
Mileage Histogram twowheels Fuel Economy Forum 0 06-19-2009 08:18 PM
Sedan better gas mileage than LB? 5 month gas chart included flint_mica_manual General Yaris / Vitz Discussion 24 03-09-2009 09:24 AM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 01:32 AM
