Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
did the effective diameter of the wheels change...did you calibrate your odo to compensate ?
#2 | |||
First time DIYer
the best GPS i have is my phone, and i don't trust that, at all. plus, i've never found it to be truly accurate. then again, i've always considered my speedo to be "the standard" for my speed. would the dealership be able to calibrate it for me? i'll give the gps thing a try, first, though. Quote:
yes, my interior got soaked beyond belief lol, but the extent of the damage was to both front seats and the carpet on the far left of the driver's area. the only electrical components that may have been affected were insulated wires running under the driver's side door sill panel thing. they were covered and insulated properly. i'll give the taking off the battery thing a try... i haven't tried anything other than the diy-cruise, which i had pre-mpg drop, the wheels, which was pre-mpg drop, and the fuel cleanser, post-mpg drop.
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs |
![]() ![]() Drives: '09 Yaris Sedan Join Date: Oct 2009
Big wheels and tires are personal choice. If you like the look, let the mileage go. The heavier wheel and tire is not the only issue here. It is the larger distance from the center of rotation that is the big problem. It is easy to imagine a figure skater doing a spin. When arms and a leg are close to the body spin speed goes up. As the arms are put out away from the body, the skater slows. Same skater and weight, but slow spin when mass moves away from the spin axis. This is why a high wire walker carries a long pole. Performance can benefit from shorter side walls but only to a point. A larger overall diameter will make acceleration suffer. Less movement usually has the driver push on the gas more...less fuel economy. I'm looking to use 14" BBS wheels with a 185/70/14 tire for next summer. I 'll report milage at that time. Currently I have less than 4300 miles. I have averaged just over 40mpg with a one time high over 44 mpg.
I think the gps is way more accurate than an odometer. I just got a newer model and it recalculates much faster, aquires sats much faster and has better featuers than one I got for the wiffe two years ago.\ Madmax, an Altima I had '05 was off 2-3% on the odometer. I think it hurts the lease holder as the clock reads more miles than you drive. doc |
| -Mileage Thread- -Log your mileage, year, model, color, any problems here... | Kal-El | DIY / Maintenance / Service | 322 | 07-20-2016 11:07 AM |
| 2009 Yaris Mileage | wornways | Fuel Economy Forum | 3 | 07-29-2009 12:42 PM |
| Mileage Histogram | twowheels | Fuel Economy Forum | 0 | 06-19-2009 08:18 PM |
| Sedan better gas mileage than LB? 5 month gas chart included | flint_mica_manual | General Yaris / Vitz Discussion | 24 | 03-09-2009 09:24 AM |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 01:32 AM |
