Old 11-13-2009, 01:23 PM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
At what RPM VVT should be activated?
For who don't know I am full standalone engine management and I have the grace to set the VVT to engage and disengage at whatever RPM it needs.
The only thing I know for sure is that when VVT activates it needs more extra fuel to work properly
The VVT is connected with General Purpose output 1 as shown in the picture. For now it is set to be ON @ 3525rpm and OFF @ 6712rpm. It also have DC ON option but still don't know much on that for now.
So as the title says At what RPM VVT should be activated? Why and what I need to know before I play much with this?
Parmas is offline   Reply With Quote
Old 11-13-2009, 02:05 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
vvti is NOT an on-off switch. it's continuously variable from idle to redline.
leave it alone ;)
Old 11-13-2009, 02:18 PM   #3
Parmas
Parmas's Avatar
leave it alone ;)
Could you make me understand more regarding VVTi?
Why the tuner set it above 3K and not from 1K so?
Old 11-13-2009, 03:28 PM   #4
127.0.0.1
check it
http://www.billzilla.org/vvtvtec.htm
Old 11-13-2009, 04:02 PM   #5
Parmas
Parmas's Avatar
Originally Posted by 127.0.0.1 View Post
Thanks for the link mate sure it refreshed my mind.
From what I understood in simple words...
VVT - needs signaling to operate on and off
References:
"The early VVT system was relatively simple, ie, at a specific rpm (~4400rpm on the 20 valve 4AGE's) the computer signals the OCV to open, this lets oil pressure go through a special gallery in the #1 inlet cam bearing, through the centre of the inlet cam to the VVT pulley"
"When the computer signals for the VVT to operate, the OCV opens and thus causes the VVT pulley to advance the inlet cam timing by 30°, reference the crankshaft"
Regarding VVT-i there is not much details so I assume is more or likely to operate similarly to VVT.
"Since the two different cam timing's will make different power throughout the rev range, (advanced inlet give more top end power at the expense of low end power, and vice-versa) there is a point where the power will be identical for both cam settings, and this is where the VVT is programmed to operate"
So I ask, what is the normal VVT rpm range of the 1NZFE?
Also what about VVT on turbo engines? Is there any variable cam turbo engine?
Old 11-13-2009, 09:04 PM   #6
JayTee09
4dr=FTW
JayTee09's Avatar
Drives: Yaris Sedan
the only toyota vvt turbos That I'm Aware Of was the late 1jz and possibly the 3sgte, I would start there, specificly the 3sgte, it was in the lexus IS250
JayTee09 is offline   Reply With Quote
Old 11-13-2009, 11:05 PM   #7
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
There is VVT and VVT-I the "I" stands for intelligence meaning it varies it's self throught out all RPM's through its controller/computer it's not an on/off thing or set to engage at any certian RPM
Old 11-14-2009, 11:02 AM   #8
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
he is full standalone though.
Old 11-14-2009, 10:00 AM   #9
Parmas
Parmas's Avatar
What do you think about VVT-i setting up Garm? You are standalone aswell right?
Old 11-14-2009, 01:58 PM   #10
AlexNet0
AlexNet0's Avatar
yes, however it needs to be controlled variably, not on/off, and since he is full standalone, he needs to find another way to do it, since that function was of the ECU that he no longer has.
Old 11-14-2009, 11:21 PM   #11
lilredrocket
Slowy getting there
Drives: 08 Liftback
His actually had to be programed for VVT-i because his did not come compatable with it so he took it to the manufacture to get it done
Old 11-15-2009, 12:29 PM   #12
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
are you using a chip? what are you programming? Hows does that work? I am very interested.. please let me know.
chongopants is offline   Reply With Quote
Old 11-15-2009, 05:00 PM   #13
Parmas
Parmas's Avatar
Well I found out that probably the ecu is only capable to control VVT not with intelligence but still to check about it.
Also there is a VVT tuning map accordingly....
Old 11-16-2009, 10:11 AM   #14
d1nzfe
Drives: 1NZ-FE
can u put up a review on this GoTech PRO X? I'm interested in it.
d1nzfe is offline   Reply With Quote
Old 11-16-2009, 07:01 AM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
imagine that, you figured out what i told you in post two!!!
Old 11-16-2009, 10:27 AM   #16
Parmas
Parmas's Avatar
Well post 2 was a like leave it alone and not you don't have control of it... although here we are in a forum and I would expect some help to solve problems either than let all go (from an "expert" like you tamago)
RE: d1nzfe .. I would be making a review as soon as all issues are solved etc...
Old 11-16-2009, 01:35 PM   #17
jouna
jouna's Avatar
Drives: jdm yaris sedan
i know some crazy yaris mo fo's and they think the vvt-i is like a vtec and they put the vvti to turn on with a button and it actually gives them 6 whp can somebody explain dis shit!
vvti bregao!
jouna is offline   Reply With Quote
Old 11-16-2009, 01:38 PM   #18
127.0.0.1
only VVT-i L is the V-TEC style with 2 cam lobes. it changes timing, lift, and duration
VVT-i L almost doubles horsepower if properly engineered.
plain old VVT-i is not Vtec. single cam lobe. it just changes timing.
yaris and yaris S Y@R15 General Yaris / Vitz Discussion 54 09-14-2009 12:40 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. dtbrown Performance Modifications 13 03-29-2009 04:35 PM
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 04:16 AM
RPM problem. rwseattle Performance Modifications 7 04-03-2007 11:09 AM
