Old 12-08-2009, 09:48 PM   #1
dybbuk
dybbuk's Avatar
Drives: 2008 Yaris HB
E-Brake
Hey guys, havent been around in a while. Can't afford to do anything to the car, but, here's my problem....Me and the gf use the parking brake 95% of the time. Now that it's gotten cold the goddamned thing seized on me tonight. Is this a warranty issue? It's only happened since it got cold. Should I be calling roadside and tearing a strip off of somebody or wtf? I'm PISSED. I pulled out of my driveway and got stuck on a little patch of ice for twenty minutes and the brake still wouldnt let go, just cooked.
dybbuk is offline   Reply With Quote
Old 12-08-2009, 10:22 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
If I pull up too hard on mine, it often catches at the top and is really difficult to get released. I've learned not to yank it that hard. I'll bet it gets to be more frequent as the brake wears and the cable needs readjusting.
Old 12-08-2009, 10:58 PM   #3
bronsin
bronsin's Avatar
I make it a habit NOT to use the parking brake except when really necessary. (which in flat NJ is never) For one thing in winter your asking for the cables to freeze up if water gets into them. Car wont move and the only cure is a heated garage the car will have to be towed to. For another everybody FORGETS to take the PB off thus wearing out the rear brake shoes prematurely. No parking brake for me!
Old 12-09-2009, 08:00 AM   #4
Yaris Hilton
Smile
It's been 20+ years since I left a parking brake on. Becomes obvious pretty quickly, anyway. The freezing cables point is well taken.
Has anyone studied the Yaris shop manual regarding how the rear drums are adjusted? One way it's often done is by applying the brakes while the car is moving rearward. Another way is that they're adjusted when the parking brake is applied. If it's set up that way and you don't use the parking brake, the drum shoes will get out of adjustment. (I've known people who never backed up and got their brakes out of adjustment, too.)
Old 12-09-2009, 09:29 AM   #5
bronsin
bronsin's Avatar
Hmm. I'll look into that! Perhaps I should have said "I" forget to replease the parking brake. On the other hand as a car mechanic I did notice how one brake shoe (the one the parking brake uses) always had half the material of the non parking brake shoe!
According to the service manual for my ECHO, you adjust the rear brakes after installing new shoes by depressing the service brake pedal several times. Thats the ECHO but Id bet the Yaris is similiar.
Old 12-09-2009, 04:10 PM   #6
Yaris Hilton
Smile
I didn't know the parking brake only worked on one drum. I'm used to cars with it setting both rear brakes. Or on my old Volvo with rear discs, it had a separate drum on the driveshaft for the parking brake.
Old 12-09-2009, 04:17 PM   #7
bronsin
bronsin's Avatar
No it works on both drums. But usually only the leading shoe is pulled into position by the pb lever. So one shoe often looks shot while the other has like half or more material left. Yeah my wifes VW Fox had the drum within the disc pb too I think. Crazy!
Old 12-09-2009, 06:30 PM   #8
Yaris Hilton
Smile
Oh, I see what you mean.
Old 12-14-2009, 07:17 PM   #9
PhilD424
Drives: Red Yaris
If you never use the parking brake your rear drums are going to go out of alignment. It should be a habit to use the parking brake every time except in extreme cold weather. And yes, backing up does help to keep them adjusted so your parking brake lever doesn't go up to far. If you work on your own car, about every oil change its a good idea to get at the drums and adjust them up by turning the adjusting wheel on the drum. Its also good to clean the drum with brake cleaner to get gunk and dirt out of it. You shouldn't have to mess with the cable unless it rots out and breaks and needs to be replaced which doesn't happen often.
-Phil
PhilD424 is offline   Reply With Quote
Old 04-15-2010, 01:11 PM   #10
b_hickman11
Drives: 08 Sedan
I'm assuming you are only talking about the MT?
Old 04-15-2010, 03:26 PM   #11
1stToyota
1stToyota's Avatar
It's a good idea for an auto also. No need to let the car roll until the slack is taken up by the driveline.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 04-15-2010, 03:11 PM   #12
127.0.0.1
the parking brake pivots are what usually seizes. remove wheel remove drum bash the stuck parts grease with brake-rated grease (doesn't catch fire) reinstall done and done
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
