AKA Samurai Racer
Need URGENT HELP PLSS !!
hey guys
installed the K&N sri setup , as per the book , but car ideling very low and eventually cuts out , what is the porblem ?? all pipes are on and working |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
the air sensor(I think thats what its called?) attached?
-Jen <3 ![]() Quote:
AKA Samurai Racer
yeah , air sensor AKA mass airflow meter is on.
Drives: yw calls me douche and racist. Join Date: Aug 2007
AKA Samurai Racer
everything is on and plugged in as per instructions , im not sure of the air sensor is maybe faulty ? or if the vacume switch can cause the car to idle so low ?
come to think of it , with the OEM intake on the car did occilate quite hectically at times , like irregular ideling ,mmm , wonder what it can be ? maybe the intake made it more promenant |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
did you unplug the negative terminal completely for at least 15 minutes? When I installed my AEM I just unhooked the battery during the install and I was fine.
AKA Samurai Racer
yeah , i unplugged the terminal while installing , then reconnected when done , was off for approx 50min
Modded Moderator
Any chance the MAS was damaged? Any check engine lights?
AKA Samurai Racer
i took the MAS out agian and checked , didnt see any damage , no engine check lights. scangauge also didnt pick anything up.
AKA Samurai Racer
can the idle be set on the yaris ? maybe the dealer can set it with the ODB2 port tester ?
Modded Moderator
Honestly I don't know but if I had to guess I'd say no as this is something the ecu probably handles... But go ahead and correct me if I'm wrong.
AKA Samurai Racer
i wonder if alot of driving will sort it out? idling is very low , approx 400rpm - 500rpm
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Strange. I just installed this unit without a problem. I wish I had something else to add ...
Subcompact Culture: The Small car blog |
#14 |
Idle is not adjustable. It does sound like a MAF problem.
My Yaris always rpm hunted, I never liked that about it.
#15 |
AKA Samurai Racer
yeah , could be MAF , i wonder if it isnt mabye dirty or somthing ? i did notice a little bit of black dirt on it , gave it a little wipe , but not properly. is a MAF very sensitive or a little robust ? how can you clean a MAF ?
#16 |
try resetting ecu and cleaning maf
#17 |
AKA Samurai Racer
already reset ECU , but havent cleaned the MAF , i did notice some black dirt on the one side of the sensor , how do i clean that off ? dont wanna break it
#18 |
AKA Samurai Racer
i noticed in the K&N sri setup there is a small oval shaped piece of metal at an angle in the intake , why is it there ? to create wind turbulence ?
| Urgent! How to use auto transmission? | hans_fh | General Yaris / Vitz Discussion | 55 | 04-16-2010 01:45 PM |
| Yaris DOWN! Help! Urgent! | mc_emily | New YARIS Purchase Forum | 8 | 09-04-2009 08:32 AM |
| EGR Error, Urgent Help Needed | aliraja | DIY / Maintenance / Service | 27 | 04-29-2009 07:59 AM |
| how can u test a sub? URGENT | Sway84 | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-09-2007 02:16 PM |
| urgent info needed..(before going shopping) | seanele | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 07-02-2007 10:07 PM |
