Old 01-17-2010, 07:57 PM   #1
TwoBearWisconsin
TwoBearWisconsin's Avatar
Drives: 2010 Yaris LB/5, 1996 Miata
Center Cap Question
I'd like to replace my wheel covers with some chrome trim rings and center caps. How can I tell if these center caps would fit the Yaris's standard 15" steel wheel? http://cgi.ebay.com/ebaymotors/TOYOT...essories#rpdId
TwoBearWisconsin is offline   Reply With Quote
Old 01-20-2010, 05:38 PM   #2
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
i may be wrong but i think those are for the alloy wheels not the steelies.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 01-20-2010, 07:28 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
+1
Old 01-22-2010, 12:49 AM   #4
Snappy
Drives: 2 Yaris Hatchbacks
I bought a couple pairs of this style center cap, one pair from this seller.
http://cgi.ebay.com/ebaymotors/1996-...Q5fAccessories
The pair from this guy had 8 plastic clips spaced out evenly that held securely over the center protruding part of the 15in steel wheel. The other set I bought from someone else only had 4 clips, and was not as secure. I was happy with this look myself.
I searched ebay for Corolla Center Caps.
Snappy is offline   Reply With Quote
Old 10-13-2010, 01:12 AM   #5
.Kevin.
I ain't even mad
.Kevin.'s Avatar
will those fit on the 15 inch steelies
Old 10-13-2010, 11:02 AM   #6
RedRide
RedRide's Avatar
Yes, they are the same exact ones I have on my Yaris.
http://www.yarisworld.com/forums/sho...ght=trim+rings
Old 01-22-2010, 04:38 AM   #7
coffiend
coffiend's Avatar
Drives: 08 Black LB
i will sell you all 4 of these caps for real cheap if you are interested.
Old 01-22-2010, 11:33 AM   #8
Mead
Drives: BSP Yaris LB 2007
i'm interested... check PM
Mead is offline   Reply With Quote
Old 01-26-2010, 03:19 PM   #9
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
send a pm to lilredrocket on the trim rings...he has some on his that look good.
Old 01-26-2010, 07:23 PM   #10
coffiend
coffiend's Avatar
Drives: 08 Black LB
Mead you've been PM'd check please.
Old 01-26-2010, 08:39 PM   #11
YAR1S
YAR1S's Avatar
Here's another option. It's what I currently have setup on my car.
They are the stock steelies(take off hubcaps).... with trim rings (can be found at any autozone/advanced autos/O' Reileys for about $10-11 per wheel... keep in mind that you need 15" sized trim rings or whatever size rim you have if your not sure buy one try it out and if it doesnt work take it back and get the next size up!
Give your wheels a good ole scrub down before you put the trim rings on.... the key to this look is to keep your steelies as clean as possible. Once the rims and tires have been cleaned get youself some tire shine..... spray the tires AND a little bit on the rims... let the tires dry on their own but get a rag and smoothe out the oil on the rims so you dont get spots where the spray has dried.
Now put on your trim rings.... align the holes with the air stem ;]
As for the center of the wheels... you should already have chrome nuts... polish those suckers up....
and Personally I added "dust caps" from NAPA to the centers to clean up the look especially since the axle on the front wheels are visable.
The dust or "center" cap is from Napa's Balkamp catalog # 730-2411
they are only a dollar or two per cap.
When you get the caps they will be a little bit too large and will fly off... so you will need some 3m double-sided tape (home depot/lowes), one or two layers will do it... dont be shy with the stuff.... apply the tape on the inside of the cap... before putting the cap on... this will make it easier. Once the tape is on... press onto wheel... use a rubber mallet to get it all the way on there... (btw these are removeable but should stay on till you need them off... no need to take them off to clean your wheels.
annnd..... wa-lah!
your done.
-Jen <3
Old 01-30-2010, 07:08 PM   #12
TwoBearWisconsin
Yar1s: that's the look I want! Thanks!
Old 01-30-2010, 09:56 PM   #13
YAR1S
YAR1S's Avatar
:) no probs.
-Jen <3
Old 10-11-2010, 07:15 AM   #14
SimTronik
Machinist
Drives: Yaris sedan 2010
Thanks YAR1S i definitly working to have this set up ready for winter ;)
SimTronik is offline   Reply With Quote
Old 10-12-2010, 10:58 PM   #15
SimTronik
Machinist
YAR1S, i'm searching and searching for the center dust caps and can't find it. Can you find some for me or buy me some and i'll pay you trough paypal? I like the fact they are chrome.
Old 10-28-2010, 07:39 PM   #16
matthewai
matthewai's Avatar
Drives: it is kinda stock
i got the dust caps but i dont think i put them on right
do they make a full cover that attaches with the 4 lug nuts? like on police cars
http://cgi.ebay.com/ebaymotors/MAZDA...s#ht_942wt_941would these work
center caps for 15" steelies? Lewis Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 07-02-2018 02:50 PM
Center cap for OEM alloy SilverBack Willing to Buy by private party 2 06-04-2009 04:12 AM
Center Cap help Brian Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 02-25-2009 07:18 AM
radiator cap question mikenacarato Cosmetic Modifications (Exterior/Interior) 5 11-24-2008 03:27 AM
center cap removal djfuji Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 02-23-2007 12:38 AM
