![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Attn: '09 / '10 owners w/ fog lights...
I purchased a fog light kit for '09 / '10 LBs here:
http://cgi.ebay.com/ebaymotors/ws/eB...m=150401427321 I've installed the kit, but have found that there are gaps b/w the fog lamps and the bumper and the fog bezels and the bumper: ![]() ![]() Do you '09 / '10 guys have these gaps as well? |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
Well if it counts for anything, I have a very similar kit for my 2008 Sedan and I have the exact same problem. I'm pretty sure I saw the same issue pop up in one of the tutorials as well.
I didn't think it was that big of a deal, as you need to really scrutinize the fogs to even notice that. It looks pretty near stock otherwise
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
I had the same problem in a set I got from Microimage. The lights themselves are great, but I ended up buying the shroud from the dealership. Fit perfectly after that.
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
wow, FINALLY ebay has 09/10 fogs, not like i need it now. Maybe head and tail lights arent far behind.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
Thats the issue with ebay fog lights. I think actually pretty much all the aftermarket fog lights for are car are made from the same place cause they all seem to have that issue no matter where you buy them from. What I did is used a dremel tool to grind down the housing a bit and a heat gun to flex and mold it to fit better. But in the end i went and bought the oem housing from the dealer. I have a 08 so slightly different than 09 but i costed me 15 dollars a piece i believe for the housing.
![]() ![]() Drives: 09 Yaris 3 DR HB Join Date: Jun 2009
if you are intereseted i have a set of 09 bezels ill sell you for 35 shipped, brand new from Toyota. Just PM me
#7 | |
![]() ![]() ![]() Drives: Toyota Yaris Sedan 2009 Join Date: Sep 2009
i'm interested :)
![]() Drives: '09 yaris 3DR Join Date: May 2009
I've order the same fogs from the seller last month & they fit right on...
So you think I just got a dud kit?
I don't know... I can't say, I would re-check if the fog light was install on it's proper place.
It is installed "on it's proper place". I have installed fog lights before and am very sure I installed these correctly.
At this point you might have to get original 09 bezels from Toyota.
| my Projector Fog lights project | ezhacker1 | Cosmetic Modifications (Exterior/Interior) | 3 | 01-10-2010 05:21 PM |
| Fog Lights Poll | Reeves360 | Cosmetic Modifications (Exterior/Interior) | 14 | 12-27-2009 02:00 AM |
| Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) | Lafiro | Cosmetic Modifications (Exterior/Interior) | 2 | 06-12-2009 03:56 PM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-02-2006 11:38 PM |
