![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
I've never done this myself, and would like to know the proper way to do it since Toyota stealer-ships charge a good amount for what i can only see as something that's fairly easy to do.
![]() Any one want to take on a photo DIY for Throttle Body Cleaning? ![]() or at least a couple tips on what to touch and what not to touch when cleaning. |
Step 1 remove air intake assembly from throttle body
Step 2 spray throttle body assembly with carb cleaner Step 3 whipe with rag Step 4 put back together |
foIf there is a big interst i might take pics and make a diy on my day off this thursday im curiouse how my own throttle body looks at 25k miles. Ill post a DIY on how to do seafoam treatment of intake manifold too.
Which some shops call fuel injuection or throttle body cleaning. Even though thats not entirely what it is. |
so It is easy to do.
Any specific cleaners? Is Carb Cleaner alcohol? Yea the Sea Foam thing sounds cool... would you have to change the oil after that kind of treatment? |
Audio Junky
would love to see a step by step for the seafoam the intake manifold. I've only done the seafoam on old carburetor type engines. I was thinking i'd foam my yaris when I get in the neighborhood of 60,000 - 80,000 miles. At 42,000 right now.
Yea I would love to see a Sea-Foam DIY.
So when cleaning the Drive By Wire Throttle Body, is there a way to move the butterfly other than with your finger? Also should you start the motor without the airbox in place like the old carburetors? ![]() I took my air box off and had a hard time moving the butterfly so i could not clean my throttle body as good as i would like. |
![]() ![]() Drives: VIOS Join Date: Nov 2009
we need to open the butterfly valve right?..or just spray with the valve closed?
Once you have cleaned it , install a catch can on the engine breathers
your car will thank you for it . And so will your wallet |
They're typically quite sturdy, but I've never seen the one on the Yaris. When I clean the TB on my Jeep I either manually open the valve with my finger or use the mechanical lever on the side of the TB.
ok..i had a fren done on his yaris sedan..
what to do, turn your key to ignition on (dont start your car!!), asked a second person or put a brick on the accelerator paddle..then your butterfly valve will open.. we have to do so as our car is DBW-Drive by wire..for drive by cable, no need to turn your key to ignition, just press the paddle to the metal..:) |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
you can take off the hose to the brake booster or any other thing that the intake has vacuum on...slowly pour the seafoam in there or buy a metering device from the auto store.
the metering device has a fitting that slips into hoses and is like an orifice and slowly allows product to mix with air and still maintain vacuum. it looks like a stepped drill bit or speed bit but it's plastic or rubber. or, there's another that's pressurized and hooks up to an air hose and you put it in front of the throttle, after the MAF and it'll clean the throttle as well as the idle air controller. |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Usually throttle body cleaning if its ever done at all is carried out on extremely high mileage vehicles ,what symptoms are you getting that your 07 car needs a throttle body cleaning?
#14 |
My millage is @ 87,000km in the last couple months there has been some sluggish performance and i was getting a 100 more km per tank a few months ago.
#15 |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
I don't notice lost performance but can confirm that winter temperatures and possibly winter blend fuel steal nearly 100 kl. per tank from my sedan (Southern Ontario). I go from 6+ commutes to 5+ commutes per tank come winter.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#16 |
Yea and the softer winter tires eat a lot of fuel. Good to hear im not the only one with this problem.
Going to check the spark plugs today... maybe they are really dirty. |
#17 |
![]() ![]() Drives: 07 Yaris Sdn, 97 4Runner Join Date: Jul 2006
Preventative maintenance. Why wait until it's really bad?
#18 |
Cleaned the throttle body and the spark plugs yesterday... She starts way quicker with fewer turnovers.
| I need a body kit | LA Yaris | California | 1 | 11-06-2009 01:26 AM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
