![]() Drives: 2008 yaris Join Date: Jan 2010
exclamation point
the exclamation point is lit up on my dashboard and wont go away. There's nothing wrong with my tires.
anyone know why its still up thre? |
just sayin air pressure is not right.. but if you check them and there fine one of the sensors are bad then. have you put fix-a-flat in them at all?
#3 | |
USAF_SrA_E-4
low pressure or you have custom wheels with out the sensor
i had a popped tire which i put fix a flat in but then i got all 4 tires replaced with new tires and the ! is still there
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
you ruined your tire pressure monitor by using fix-a-flat..... NEVER use fix-a-flat
#6 | |
working at big O for the past 2 months and ive bet ive put in 100 cuz ppl put fix a flat in the tire.... its crazy but it eats the base of the sensor and destroys the chip inside. my buddy at toyota told me a while ago when i tried to help a friend she had replaced one and it wouldnt read the new one, so i tried to get it to program with our tool at work. but the only way is to have the toyota read and program the serial number in. |
so the sensor is fucked
is there anyway to get the ! off the dash ? |
ah.. a quick question like that..
does insurance say a thing about the tire pressure monitor if an accident occurs? I mean, if you don't give a shit about the sensors, and you know for fact your tires have the right pressure?? |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Buy a new sensor and have it installed
resident senior
Remove the light bulb behind the !
help! my Yaris shrunk!
Drives: 12 Hot Lava iQ/07 Jade Vios Join Date: Jun 2007
It won't go away until you finish the quest
![]() ...which is to get the sensors replaced XD |
#12 | |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
Half a Bubble Off Plumb
Stick a piece of black electrical tape over the (!) light.
#14 |
#15 |
DAT'S RIGHT I GOTz 2
why didnt you use your spare tire?
did you remove it ? if you did that would be the reason for the light on the spare has a sensor too! if you didn't did you check the tire pressure of the spare?
#16 |
| ABS and "!" lights are ON again! | onizuka | Canada | 457 | 04-28-2023 09:40 AM |
| Yaris at Summit Point Time Trials | Redbat01 | Tracking, Racing, Auto-X Forum | 1 | 05-06-2010 12:30 PM |
| exclamation point shown on a 2008 toyota yaris sedan dashboard | SoundWave | DIY / Maintenance / Service | 16 | 06-25-2009 10:49 AM |
| just got back from cedar point... | joey1320 | Off-topic / Other Cars / Everything else Discussions | 2 | 06-15-2007 11:01 PM |
| Friction Point - Clutch | hal9000 | DIY / Maintenance / Service | 17 | 12-01-2006 03:55 AM |
