Old 10-03-2010, 07:23 PM   #1
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Bolt Size
I suppose that this is a DIY question.
I'm gettting some "summer alloy" wheels, and using my steelies as winter wheels. I've got a torque wrench but the largest socket I have in my set is a 19mm, which does not fit on the lug nuts.
So, what size are the lug nuts? Sorry if this is a noob question, I just want to save myself the hassle of buying a bunch of various sized sockets.
Old 10-03-2010, 08:07 PM   #2
Yarisduder
Yarisduder's Avatar
Drives: 2007 4dr Sedan Silver Streak
You could measure the size of the socket on the emergency wrench.
Yarisduder is offline   Reply With Quote
Old 10-03-2010, 11:15 PM   #3
21mm or 13/16"
Old 10-04-2010, 07:58 AM   #4
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
CTScott, you are the man!
I'll post pics once I've got the wheels on.
Old 10-04-2010, 08:07 AM   #5
big lo
big lo's Avatar
Drives: 2007 VIOS
I'm telling you guys for the longest CTscott works on the down low with Toyota lol
Old 10-04-2010, 08:54 PM   #6
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
21mm socket worked perfectly! Everything snugged up to 75 lb-ft of torque.
And the results!
Old 10-06-2010, 08:44 AM   #7
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i got a question that deals with the lug studs. is the thread pattern the same as honda's thread pattern? i got a set of rims but the diameter of the hole doesnt quite fit my 21mm socket which is a 12 point skinny socket. but they do work on my crx which uses 19mm socket. is the thread the same as the honda civic/crx 4x100 studs?
i could easily find out this weekend but im at work and figure this would be a good information if anyone else had this question.
Old 10-06-2010, 08:56 AM   #8
The CRX also uses M12x1.25 lug nuts, so the studs are the same, but the outside of a lug nut can be any size. For example, the stock lug nuts that came with my Yaris steelies use a 21mm socket, as do the lug nuts that came with my Toyota TTE alloy rims, but the lug nuts that I need to use with the mini cooper rims (that I run as my winter rims) use a 19 mm socket.
Old 10-06-2010, 11:39 AM   #9
ilikerice
ilikerice's Avatar
BAAM.. question answered thanks a bunch. that is the same prob u have with ur mini rims as i do with my rota's off my crx. i got some 225/50/15 khumo v710 tires on those and gonna be running those on the yaris next event. i like how most of my tire stuff is interchangeable from my crx. less things to buy.. thanks again. greatly appriciated
What size allen wrench for auto transmission drain bolt? detroiter DIY / Maintenance / Service 6 03-30-2019 02:55 PM
Bolt Pattern Size and Offset for the Stock Wheels fmicle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 08-12-2009 03:35 PM
head bolt socket. What size? beemer dave DIY / Maintenance / Service 3 06-02-2009 04:15 PM
Transmission Drian Bolt washer size CB900F2 DIY / Maintenance / Service 14 12-07-2008 07:03 AM
