Old 12-23-2006, 11:28 AM   #1
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Got my TWM Short Shifter but...
...there are some minor differencies between my gearbox and the american Yaris, so I am gonna need your help.
However, I have some questions, cause my gearbox is slightly different than that in the manual.
First difference(driver's side)
Second difference(driver's side)
Third difference
Fourth difference
Fifth difference(passenger's side)
Basically, I need some instructions on how to remove the two screws(pics 1-2) and how to remove the ball(pic 4) cause there is nothing to pull out and I cannot do what steps 7 and on(TWM Manual) say.
Thanks to all!
Old 12-23-2006, 11:13 PM   #2
dngz
dngz's Avatar
Drives: black yaris sedan
wow urs look really different ><"!!
dngz is offline   Reply With Quote
Old 12-24-2006, 03:48 AM   #3
Katana
Katana's Avatar
Ηaha, the basic structure is the same, but there are some differencies that make it difficult to me to install it!
Old 12-24-2006, 06:07 AM   #4
sorry to hear that dude, and it's not very clear formt he pics what kind of fasteners are used. The easiest way would be to dremel them out, but you'd need to re-use them afterwards so that's not so much an option...
Good luck!
Old 12-24-2006, 07:08 AM   #5
Katana
Katana's Avatar
Yes mate, this is the problem.The fasteners are different than those in the printed manual.Maybe I will end up paying a technician to do it!Dammit, I also paid a lot of taxes in the airport(60 euros!).
Old 12-27-2006, 02:37 PM   #6
Katana
Katana's Avatar
Αhhh, I am going to install them with a professional!It is hard to do it myself and Kevin hasn't got any ideas...
Old 12-27-2006, 11:54 PM   #7
acrbill
Drives: Polar White Hatch
Its hard to tell but in the first 2 pics I think I see a snap ring. I am not familiar with the shifter in the Yaris so I cannot be of too much help here. Just try taking out the snap rings and see if that releases anything.
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 12-28-2006, 03:34 PM   #8
Katana
Katana's Avatar
This is the basic idea, but I am not quite sure hiw to take them out.
Old 12-28-2006, 03:35 PM   #9
acrbill
snap ring pliers.
Old 12-28-2006, 03:37 PM   #10
Katana
Katana's Avatar
I will look into it.Thanks!
Old 12-28-2006, 05:52 PM   #11
acrbill
You could probably get away with hitting the snap ring with a screwdriver to pop it off. It looks like that pin would slide out then. Once thats off figure out how the part that comes off the side of the shifter ball attaches to that plastic and remove it. Remove the linkage from the bottom of the shifter and you might be able to pull the shifter out.
Old 12-28-2006, 06:06 PM   #12
Katana
Katana's Avatar
Basically, if the rings are difficult, the bottom linkage is inhuman.I mean, I cannot understand how to pull it out!
Thanks again for your concern.
Old 12-28-2006, 06:46 PM   #13
punch
punch's Avatar
Third difference
Fourth difference
Thanks to all!
ok from what i see, and what the twm instructions show, should be very similiar,
1. first remove the shift linkage, which is in your secound picture. (step 3 of twm instructions)
2.then remove whatever is holding the bottom of that item in step 4, not triing to remove the ball from the cup yet.
3. get yourself some spring clip pliers to remove that clip from the pic in #2 picture,
4. once the clip is removed hammer out that pin, the shift assembly looks like it would then pull straight up
good luck
punch is offline   Reply With Quote
Old 12-28-2006, 06:57 PM   #14
punch
punch's Avatar
good luck
XXXXX on another note look at the install insturctions for the tercel, might add some help, seems simple to me???
Old 12-31-2006, 01:14 PM   #15
Katana
Katana's Avatar
Thanks for your great help.
I will try to do it when I return from holidays.
Old 01-23-2007, 01:34 PM   #16
Katana
Katana's Avatar
...and today I fitted it!
It is great.In fact, it is more than great.But, I had a lot of trouble fitting it to my gearbox cause the ball in the middle is smaller than the gearbox's hole and I had to find something to make it fit.
Anyway, I did it and it is great.Really fast gear changes, excellent feel.
I will upload pics soon.
Thanks Kevin from TWM Performance.
Old 01-24-2007, 12:42 PM   #17
Katana
Katana's Avatar
Here are some pics.
Before:
After:
twm short shifter installed! dngz Performance Modifications 115 08-02-2007 01:11 PM
November: Big Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 14 12-12-2006 10:50 AM
Having Trouble with TWM Short Shift Install. Need Help xfatefailsx07 Performance Modifications 3 10-10-2006 01:38 AM
TWM Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 9 08-28-2006 03:37 PM
TWM Short Shifter/Shift Knob Sale! TWM Performance Performance Modifications 0 07-17-2006 05:08 PM
