![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Is there any product that can help reduce engine noise into the cabin?
I've eliminated most sources of sound into the cabin, but the engine remains a loud source, especially at higher RPM.
I was wondering if there's any product, generic or yaris specific, for covering/creating a more solid sound barrier under the hood? I've seen under the hood of Audis and BMWs; they have large strong shields over the top of the firewall and engine, in addition to the firewall itself. Have anyone tried making something similar for the Yaris?
I should have mentioned that I've already laid down mat in the car. I have dynamat-equivalent material on the hood, front footwells and doors and floor etc. Engine sound is still present to a small but noticeable degree.
![]() ![]() Drives: 2010 5 Door Join Date: Jan 2011
Did you do the fire wall? That is where most of the sound will come through.
#4 | |
Or should I do the firewall from the side of the engine? |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
You can order the insulation for under the hood . That could help as well .
Spray sound deadener in the wheel wells. This will make a BIG difference in cutting road noise (and some engine vibration/noise as well). Toyota didn't put much of anything on those surfaces.
I would not try to deaden the firewall from the engine side, just my opinion. You sure you don't have some engine problem? Should be pretty quiet, especially if you haven't added any intake/exhaust modifications.
I hope I don't :-) I've already put some rubber coating in the wheel wells, but it may have worn off since its over a year ago.
It is probably still there, I wore it on the front of my bumper for 2 years, and it never came off. If you placed it as high as you could in the foot wheel there isn't much more you can do. I'm not sure how flammable it is, so I wouldn't put it on the engine side of the firewall, but if you want to go nuts you can pull off the dash and continue up on the foot wells.
![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
can you recommend some specific spray brand or link ?
thank you |
Some science
There are primarily two types of noise you hear in your car: Sounds produced outside the cabin (e.g. your engine, other cars, yelling children...), and sounds produced by the resonance of your car's body. Each is blocked in a different way, so be certain of which noise you are trying to eliminate.
If it really is your engine, the only way to create a sound barrier is with mass. More mass = less noise transmitted. It's as simple as that. That's why dynamat and similar products are. Probably the most massive option would be lead sheets, but everyone stopped using those years ago when we realized they caused cancer. The next best option is mass-loaded vinyl. You can get it in varying densities, I've seen up to 2 lb / square foot. It really doesn't matter what product you use, as long as it is massive and flexible enough to conform to your car. Now you have to figure out where to put it. That's more tricky. I'm guessing that if you already did the usual surfaces (doors, floor, roof), you might benefit from coating the firewall directly. You need to remove the entire dashboard and then you'll see it. Be careful to make seams very neat. |
![]() Drives: VIOS Belta Join Date: Oct 2009
ear plugs..... Muhahahhaa
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
Hell, I have the opposite problem in that I can't hardly hear the engine at all! And I'll be damned if I will take a chance on some aftermarket bellowbox to help with the problem and annoy the neighbours...
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
full volume Heavy Metal should do the trick.
#14 |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#15 |
I saw this stuff at the hardware store. It comes in a spray can with an applicator straw. If you remove the center gauge cluster that will give you a nice big access hole. all you do is spray the stuff in the direction of the fire wall and it magically expands into a foam that hardens into an insulation barrier. The beauty is it conforms to any surface and should go a long way to getting rid of any hard to locate dash rattles too. Warning DO NOT get it on the outer dash surface or your clothes.
#16 |
That can certainly help with rattles and resonance noise. But how much does it weigh? I'm guessing the entire can probably weighs as much as one square foot of MLV, which means it can't stop outside sound from getting in. Sound barrier = mass.
#17 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
Spray foam also is highly flamable......and honestly the MLV is the best way to rid sound on the firewall,also put extra on the path of the exhaust on the floor boards....yaris is a noisy car....it resonates inside...especially when you take all the panels out....but that is a great way to find the resonance,all a little each day to differant parts and see if the sound changes,also put it on the back side of the interior panels as they resonate moise too.
#18 |
![]() ![]() Drives: 01 Toyota Echo Join Date: Oct 2010
Don't go with dynamat its over priced. Go to home depot and go to the roofing section and get quick roof. I used 1/3 of a roll. Get a utility knife and a few blades to cut it.
I pulled the carpet out of the car and went around the floor plan and knocked around adding pieces here and there. Then I went to the carpet padding area in home depot and bought the 1/2 carpet padding with the blue stuff on it. Point the blue stuff up so if you spill crap it won't dissolve the carpet padding. Usually you can't use regular carpet padding because it dissolves (according to auto upholstery books) when auto chemicals are spilled on it. The blue stuff is a barrier to prevent that from happening at least that's what it advertises in the store and what I hope. I formed templates and cut new padding for the entire front half of the car. Then I placed the carpet back and the oem padding. It was hard to get ahold of fiber padding. It made a big difference. I only did it because i was pulling the carpet out anyways to rent an upholstery cleaner form home depot to get dog smell and anything else out. It works great for cars. I did the seats and all. Though the door seals are in good condition. I find now that air noise is the biggest problem. Though drafts are not really an issue. |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 30 | 01-24-2024 04:26 AM |
| NST Crank Pulley Reliability? | WeeYari | Performance Modifications | 59 | 02-10-2010 01:20 PM |
| higher octane fuel | KSIbucky | DIY / Maintenance / Service | 37 | 01-14-2007 07:17 PM |
| engine noise?? | poshi | General Yaris / Vitz Discussion | 23 | 09-04-2006 10:45 PM |
