Old 03-22-2011, 07:25 PM   #1
gabriel2012
Drives: 2011 Base Sedan
Do stp cleaners work?
Well today there was a sale at a local gas station on fuel additives made by stp
The cleaners were a $1 each so I bought two different ones since that was all that was left on the shelf by the time I got there.
I bought 1 Super concentrated fuel injector cleaner(black bottle)
1 complete fuel system cleaner
I plan on using the complete cleaner on my yaris and the fuel injector for my dads truck
the bottle says it treats 21galons and I know the yaris has 11 so I plan on using half the bottle (correct me if I shouldn't)
do these things really work or should I give them away?
(I plan to use it on my yaris b/c I don't know how well the car was maintained before I bought it) and if it helps my tank is only missing one bar, almost full
http://db.tt/QIWZ2E2 Click to signup for dropbox, and get bonous space, I do too!
gabriel2012 is offline   Reply With Quote
Old 04-02-2011, 09:00 AM   #2
preston03
Drives: 2009 Toyota Yaris
I prefer the Lucas Fuel injector cleaner. It works really well.
preston03 is offline   Reply With Quote
Old 04-02-2011, 10:30 AM   #3
nemelek
DWEED
nemelek's Avatar
I use Lucas for the diesel. Have not tried on the Yaris yet.
Old 08-27-2011, 05:59 AM   #4
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
+1. Tried it once and it actually improved my rating by only 3 miles per tank, though it may have been somewhat unnecessary because I'm only at 75K on the original fuel pump and filter. Suppose someone with higher mileage could give you a better opinion maybe?
Old 04-02-2011, 10:04 AM   #5
Hershey
SHELL V-Power and the TECHRON work well . STP , haven't used that in years . There's also BG products . Can find that at TOYOTA parts departments , http://www.bgprod.com/products/products.html .
Old 04-02-2011, 08:47 PM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I used to use STP products for my 86 escort when I had it in the early 90s. did the job back then, have no idea now.
Old 04-03-2011, 12:39 PM   #7
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
Most gasolines sold today have injector cleaners as part of the additive package. This makes off-the-shelf additives somewhat redundant.
DMZ is offline   Reply With Quote
Old 04-03-2011, 01:38 PM   #8
STC
"LibertyRides!"
STC's Avatar
I don't use fuel system cleansers, octane enhancers, fuel conditioners, and gas treatment products. I do use gasoline fuel stabilizers for ethanol gas.
http://www.fuel-testers.com/review_g..._products.html
http://www.jackssmallengines.com/gas_stabilize.cfm
Cheers!
~ Mark ~
Old 04-03-2011, 08:58 PM   #9
Murtaza_murti
Drives: Toyota Belta
Do fuel injector cleaners fix a rough idle and a bad fuel average?
Murtaza_murti is offline   Reply With Quote
Old 08-22-2011, 10:31 PM   #10
A-Dingo-Ate-My-Baby
Drives: yaris
I just did a bottle of techron on my 19,000 2010 yaris HB automatic
what happened was:
-for that 1 tank, gas mileage dropped
-almost immediately, throttle response improved
-throttle response continued to stay 'peppier'
It surely had to do something to clean my injectors. My yaris
never ran bad...I just figured throw in some bg44k or techron and techron
was what I found first. it does work.
next 20,000 miles I'll do another bottle
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 08-22-2011, 11:51 PM   #11
digitalrain
Drives: 2011 yaris rs
Just curious, did your gas mileage improve after that 1st tank went down?
what happened was:
digitalrain is offline   Reply With Quote
Old 08-23-2011, 05:52 AM   #12
LEXX
0-60 IN UNDER FIVE
LEXX's Avatar
Drives: 2008 Blk on Blk Yaris Sedan
i put techron in mine about a month ago when it started feeling a lil sluggish... didnt pay any attention but it does feel like i'm not at the gas station as much... def faster and smoother... 1st time i put techron in it it felt quicker but the 2nd time was even better... i think they say it works best after 2 bottles (not at the same time)... the only bad thing about it is that it only lasts for about a month and then slowly starts to change... someone on amazon said Lubro-Moly Jectron fuel injector cleaner lasts a lot longer... i'll probably check that 1 out next
LEXX is offline   Reply With Quote
Old 08-23-2011, 08:45 AM   #13
A-Dingo-Ate-My-Baby
Drives: yaris
it seems to be the same, back to normal. but throttle response remains snappier.
I must have had some slight buildup on injectors.
This must be more noticeable on small engines, as my 5VZFE, which has 190,000 miles on it, I never felt the need
to put anything but gas in the tank since 1999.
Old 08-27-2011, 04:34 AM   #14
JerseyJeff84
Drives: 2010 Yaris Sedan
This may sound very stupid, but bare with me, I'm a car novice, but is it safe to use cleaners? My Yaris only has 16,000 on it(2010) and as much as it would be nice to use a cleaner, I'm scared of ruining the car. When I was younger, my parents used a cleaner in their 1980's Pontiac and it killed the engine.
JerseyJeff84 is offline   Reply With Quote
Old 08-27-2011, 08:10 AM   #15
A-Dingo-Ate-My-Baby
Drives: yaris
a) no risk
it is completely safe to use auto parts store or walmart cleaners that go into the tank only,
b) some risk
the cleaners that have you in the engine bay sucking into the throttle body could damage the motor if done completely incorrectly (dumped all in at once), either by hydrolock or other extreme pressure situation, or thinning of the motor oil and causing extra wear or failure
Does DFCO still work when using cruise control? rtom Fuel Economy Forum 10 01-20-2010 12:26 AM
Need Truth About Warranty Work . . . woof DIY / Maintenance / Service 17 12-12-2009 03:39 PM
Got hit at work today, lady drove off. Prohibit General Yaris / Vitz Discussion 41 11-04-2009 11:38 PM
Drove home from work with a damaged belt and... AznGouki DIY / Maintenance / Service 44 09-07-2009 02:08 AM
Idea I had, but I can't figure a way to make it work... kac Cosmetic Modifications (Exterior/Interior) 4 08-08-2009 09:17 PM
