Old 05-24-2011, 02:55 PM   #1
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
Unhappy Engine oil ?! I'm really confused
HI
i'm calling for help from EGYPT !
our toyota dealer here sucks and uses low-quality Mobil 1 fully synthetic motor oil 5w-40 ... Engine sound is too high! (10000 km so far)
I DON'T WANT TO USE THAT!!
right now , i'm using toyota genuine motor oil (20w-50) mineral oil .. (much smoother engine now)
(catalog says 20w-50 or 15w-40 multigrade SL)
HELP ME OUT GUYS ...
i'm doing okay or should i switch to synthetic ?
note : Driving in EGYPT is pretty bad! Heavy traffic + short distances + HOT Temp. (40C In summer & 8C in winter) ....
THNX!
BLOODY_STONE is offline   Reply With Quote
Old 05-24-2011, 03:43 PM   #2
Liu997
Drives: 2008 Red Yaris LB
I would say the fully synthetic Mobile 1 is the superior oil
Liu997 is offline   Reply With Quote
Old 05-24-2011, 03:52 PM   #3
BLOODY_STONE
The reason i hate mobil 1 is that it is locally made in Egypt and its got low quality ! its color doesnt change even after 5000 km driving!!!
Old 05-24-2011, 03:55 PM   #4
Kongo-Otto
Drives: '09 Yaris & '10 Auris
My (genuine toyota) oil didn't change color after 6.000 km, too. I see no problem there. Mobil 1 FS oils are well known and high quality oils.
Old 05-24-2011, 03:58 PM   #5
BLOODY_STONE
well , from what i know , if ur oil doesnt change color , this means its doing bad job in cleaning ur engine interior ...
i guess many ppl can confirm that right?
plus , in EGYPT , its really dusty weather and low quality fuel , (can you imagine changing the air filter every15,000 km?!) so , my oil should be good enough in cleaning engine interior and handling heavy traffic!
Old 05-24-2011, 04:04 PM   #6
Kongo-Otto
I don`t think the Toyota Genuine Oil is bad. 6000 km ain't much and we don't have any heavy conditions here. Car only got 13.000 km so there should not be much residue inside the engine.
Old 05-24-2011, 06:10 PM   #7
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Oil color is not a really reliable method of determining how good of a job an oil is doing. Most folks I know with a Yaris report their oil stays very clean looking for long periods no matter what oil they use.
An oil turning dark quickly may simply be oxidizing and actually building engine deposits, to give an example.
Bottom line: choose any quality oil you like from 0W-20 to 20W-50, change at a reasonable interval, make sure your air filtration is working good and your Yaris will go further than most of us would ever care to drive them!
-The Fitful One
Old 05-24-2011, 06:30 PM   #8
Happy Little Pony
Drives: 2007 Yaris HB
Either oil should work. I wouldn't worry too much. Here in the US they spec 5w30 and 5w20 for the Yaris, so I wouldn't worry that a 40 weight oil might be too thin.
Happy Little Pony is offline   Reply With Quote
Old 05-24-2011, 06:30 PM   #9
BLOODY_STONE
so , it wont matter if its synthetic or mineral ?
Old 05-24-2011, 06:42 PM   #10
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
no. What does Toyota tell you to use in your car? For the US it is on the oil cap.
Colin Chapman disciple
Old 05-24-2011, 06:49 PM   #11
BLOODY_STONE
nothing written on the oil cap ...
Old 05-24-2011, 06:42 PM   #12
Happy Little Pony
There's not a lot of difference in your scenario. In a warm weather climate with a car that doesn't have a high performance or turbo-charged engine, the benefits of a synthetic are minor. If you want to use a synthetic for a little more peace of mind, go ahead, but it probably won't affect the longevity of your engine to any great degree.
As long as you use a quality oil and change it regularly, I wouldn't worry.
Old 05-24-2011, 06:51 PM   #13
BLOODY_STONE
All i need is outstanding protection & long life ... so all i should care about is interval changing not the type of oil ...
Old 05-24-2011, 07:06 PM   #14
Happy Little Pony
Exactly. In an ideal situation, you can run a synthetic oil longer than a conventional because the synthetics tend to have a more robust additive package. But, as you describe, you live in less than ideal circumstances in a very dusty environment. That will be your problem. Keep an eye on your air filter and your air intake, making sure all of the seals are good and that there are no cracks or leaks. That will have more to do with you engine's lifespan than the oil will.
But especially keep watch on your cooling system. Check your coolant level regularly and watch for leaks! More engines end up on the scrap heap from coolant problems than from oil problems.
Old 05-24-2011, 08:19 PM   #15
BLOODY_STONE
big THANX!! considering synthetic oils ... what do you recommend?
Old 05-24-2011, 07:43 PM   #16
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Very well said, Happy Little Pony!
-The Fitful One
Old 05-24-2011, 10:02 PM   #17
Viperoni
Drives: 2005 Toyota Echo
I run Pennzoil Platinum 5w-30 that I get for $22 at Walmart and I take my car to lapping days, and I still change it every 2 lapping days or 9000kms, whichever comes first.
My oil has around 8000kms, has been through this past winter and a lapping day, and is dark brown.
2006 Saturn Ion Redline
Old 05-25-2011, 03:47 AM   #18
BLOODY_STONE
mobil 1 , castrol , shell , total ... All are API SL
We got some good stuff ... I think i'll buy my oil next time from saudi arabia (the country in the movie kingdom :-D) since they are leading in oil industries ...
Engine oil pump? zahirrahman DIY / Maintenance / Service 3 09-30-2010 01:06 PM
Performance engine Oil xbalance Performance Modifications 2 07-14-2009 03:32 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Spilled oil on engine eii DIY / Maintenance / Service 11 01-28-2009 11:30 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
