Old 01-26-2009, 07:26 PM   #1
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Spilled oil on engine
Dont ask how this happened, but I like spilled a bunch of oil around the err engine bay area. I tried to clean as much as I could, mostly what I could see. Umm, so like I went to drive somewhere real quick and I can smell some oil burning. Is this ok or is it really bad?
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 01-26-2009, 07:30 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
as long as you are sure you put the plugs back, if you spilled oil on the engine, it will burn off. Might as well double check to make everything is where it should be, and if it is you'll prolly smell that unless you do a super thorough cleaning.
Colin Chapman disciple
Old 01-26-2009, 07:35 PM   #3
eii
Rides canyon walls
eii's Avatar
I'll do an even more thorough cleaning tomorrow. I dont do a lot of driving, and when I do its short distances so I think it should be ok for the time being.
Old 01-26-2009, 07:48 PM   #4
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Go to a car wash and wash it off, just be careful using a pressure washer under the hood. Avoid letting the spray hit any electrical connections, bearings, etc. If it's just oil running down the block that should be simple.
Old 01-26-2009, 09:29 PM   #5
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
Simple Green is a safe way to get rid of oil.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
Old 01-26-2009, 11:09 PM   #6
gid
Drives: '08 Yaris sedan , '08 Liftback
yup , + 1 on simple green or window cleaner . Use that for cleanup during oil changes , dissolves very well .
gid is offline   Reply With Quote
Old 01-27-2009, 12:36 AM   #7
YarisSedan
Drives: 08 Yaris Sedan
can of brake cleaner will do wonders. Its the staple of any lube shop. Cleans oil spills in a jiff. I think my shop uses 3 boxes a week.
Old 01-27-2009, 02:07 AM   #8
eii
Rides canyon walls
eii's Avatar
Cool, thanks so much for the advice guys. Hopefully it isnt too cold tomorrow morning for me to get out and clean this stuff off.
Old 01-27-2009, 09:39 PM   #9
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
first time changing your oil yourself ??? :-)
Old 01-28-2009, 11:25 AM   #10
eii
Rides canyon walls
eii's Avatar
Oh no, not at all I've done every oil change myself since I got my car. I did something a little more embarrassing than that...
BTW I cleaned it up very well and there is no longer that burning smell. Plus it looks good as new now. Thanks for all the help.
Old 01-28-2009, 11:29 AM   #11
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
It'll smell like carbon heating up, it'll act like a shit-magnet for dirt, but that's about it.
firemachine69 is offline   Reply With Quote
Old 01-28-2009, 11:30 AM   #12
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Do Tell.... lol
leaky seal on engine? oil overfill? jeff69dini DIY / Maintenance / Service 23 06-07-2010 12:52 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
About Engine Oil Changing Manual hans_fh DIY / Maintenance / Service 4 03-03-2007 10:20 AM
