Old 05-25-2011, 04:33 PM   #1
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
Another + for MicroImage 23mm Sway Bar.
Got my 23mm Sway Bar today from MicroImage.
First Complaint: All i got is myself no help.
Second, them bolts that hold the shocks together, you will probably need a Impact Wrench Gun to remove it, forget about the sockets with hands.
Took me a good 40 minutes to get everything done, plus while i got the 2 back wheels removed, might as well adjusted my Drum Brakes with Hand Brake.
PROS: Everything, man this is totally worth $164 shipped.
Of course not 100% better, but i said from 40-70% better body roll depend.
Of course not like Porsche but i can tell you probably BMW 3 series feel.
[U]Second[U] Something i do noticed and tested. The coffee will not spill out when i make a turn, normally it's be all over my seat or dash.
The second pic with the navigation and file folder, that is it's originally position after 30 minutes drivie with about 13 turns, normally it's will be on the floor or somewhere else.
I took some pics hope i installed correctly.
Everyone got 200 bucks to spend, add this. And think about it, you drive a yaris everyday why not make it more fun to drive? i mean it's handle better, feel more solid, and kinda easy to install by yourself.
jamal1984 is offline   Reply With Quote
Old 05-25-2011, 04:56 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
impact wrench is not needed just need a breaker bar or some sort.. i had one guy to help me but i think without him its gonna be a b#$%h... that thing was so tight that i have to pull on the side to slide it to match the bolt hole.. but after it was done it was all worth it...
Old 05-25-2011, 05:16 PM   #3
SKurj
Drives: 09 Yaris 3dr HB, BRZ
The bottom bolt in those shocks is a b#tch! I happened to have a 18" bar used for weights that I put on the end of the ratchet to get them free. Yes a breaker bar is one of the next things on my list of tools..
I went with the 19mm but.. as I installed tokico blues, tein springs and the bar all at once I can't really vouch for the difference the bar alone made. Spent the first few days on the steelies and then my new wheels and tires arrived. The first day or 2 I thought the ride was abit harsh, but now that I have been driving it I don't notice it being harsh at all. Granted I do 850kms a week all on the 400 series, rarely much else.
SKurj is offline   Reply With Quote
Old 05-25-2011, 05:18 PM   #4
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I just used a 12" piece of copper pipe over the socket wrench...easy peezy. Ya'll need some grip strength. ;) ;)
-Type 07 FFL-
My odometer 03/11
Old 05-25-2011, 05:19 PM   #5
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
eww crush-bent 1.75" tubing
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-25-2011, 05:42 PM   #6
jamal1984
man i'm the weakest :)
Old 05-26-2011, 10:34 AM   #7
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
will i have to call this guy when i decide to do mine?
seriously though I think i'll only go 19mm so if anyone else is looking to upgrade theirs to 23mm (or getting rid of their TRD), let me know
-toy
Old 05-26-2011, 01:53 PM   #8
mazilla
advocatus diaboli
mazilla's Avatar
-toy
ROFL
The sad part is that arm is full of synthol, it's an oil some bodybuilders inject into lagging muscles to puff them up. It's supposed to be used on the small spots here and there, then you can't tell...but when you inject a freaking gallon of it you end up like that.
-Type 07 FFL-
My odometer 03/11
Old 05-26-2011, 02:46 AM   #9
Spahrticus
Spahrticus's Avatar
Drives: ///M3, Yaris
BMW 3 series feel? Ha, that gave me a good laugh.
Spahrticus is offline   Reply With Quote
Old 05-26-2011, 08:58 AM   #10
jamal1984
hey what's good in this life beside a good good laugh man? laugh all you want, you will live longer
Old 05-26-2011, 06:30 PM   #11
Spahrticus
Spahrticus's Avatar
Now that made me really lol
Old 05-26-2011, 07:23 PM   #12
jamal1984
there you go, glad i could help
Old 05-26-2011, 03:18 AM   #13
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I needed to geta good 10" pipe to help me get my shock bolt off. Min was rusted on like crazy. Needed some sort of shock freeze de-seizer too.
Old 05-26-2011, 12:57 PM   #14
i use pentrating lubricant the day before suspension installs.....ive never had an issue breaking anything loose
Old 05-26-2011, 01:59 PM   #15
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
been using a cheater bar for years now. it is a pipe from a service drop that I swiped from HS electronics class. it is much thicker than conduit. usually the bolt breaks free before the wrench....usually
I think that guy's arm is bigger around than my waist. lol
Need input on ULTRA RACING 23MM SWAY BAR VS NITTO REAR LOWER STRUT BRACE. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-22-2011 07:32 PM
Drum howl after installation of 23mm sway bar minnyar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-21-2010 12:57 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
23mm Sway Bar Installed! - Thanks Garm bronzebullet232 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 07-19-2009 11:34 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
