Old 05-28-2011, 04:31 AM   #1
Spahrticus
Spahrticus's Avatar
Drives: ///M3, Yaris
Quick Wheel Question *(205/50/16, 35et)*
SO, I consulted the wheel guide sticky, but had further questions.
Its seems this set up would be right on the edge of being able to work with a lowered car. I'm on DF210's and Tokico Blue's, so low, but not slammed by any means. I'm ok with rolling fenders if need be to make this happen. So here's the set up...
Wheels - 16x8 35et
Tires - Dunlop Direzza Star Spec 205/50/16
Thanks for the insight guys.
Spahrticus is offline   Reply With Quote
Old 05-28-2011, 07:58 AM   #2
Klink10
Klink10's Avatar
Take a look at pics after doing a search on here for 205/50/16. I'm running the TRD package which gives a moderate drop and that tire size you have questions about. My rim is a 43 offset and I have a 2 finger gap. I am pretty sure Barber is running the same rim in a 15" but with a 35 offset.
Anyway, check the pics. I did that for about a week before pulling the trigger.
Old 05-28-2011, 08:21 AM   #3
SailDesign
Drives: .
I run 205/45-16s, and don't notice any difference from the "stock size" tire.
Old 06-02-2011, 11:42 AM   #4
Mriyantonov
Drives: Toyota Yaris,Avensis
My Yaris 1.33 has 205/45/16 Sumitomo HTRZ.Add it has Eibach (40mm) sport springs. It better than comfort original tyre (185-60-15 Bridgestone Potenza RE080) Original tyre is really poor.Handling is disastrous
Mriyantonov is offline   Reply With Quote
Old 05-28-2011, 09:52 AM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
205/50/16 is an excellent choice with stock suspension or a mild drop like the TRD package you have.
With 205/50/16, 16x7, ET42-45 works best and requires no camber adjustments or fender mods.
Old 05-28-2011, 12:20 PM   #6
wildmongoose26
wildmongoose26's Avatar
Drives: 09 5dr Yaris
The 16x8+35 will most likely rub a bit.
Have 16x7+38 on my car and I rub. So yours would stick out about 1/2" further then mine. We have the fronts rolled a little and still rubs.
So you may have to do some decent rolling.
Angela
Old 06-02-2011, 04:03 PM   #7
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Speaking from experience, you'll rub with a 205/50/16 on a 16x7 +35 wheel. I did. A lot.
FS: Sparco Wheel, Quick Release, Momo Spacer Focus_Sh1ft Items for Sale by private party 18 04-27-2011 12:36 AM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 05:52 PM
New Steering Wheel & Quick Release Installed~! AlainMikli Cosmetic Modifications (Exterior/Interior) 55 09-01-2009 12:48 PM
NRG Thin Steering Wheel Quick Release Black kustom play Items for Sale by private party 0 07-09-2009 05:36 PM
