Old 07-01-2011, 06:39 AM   #1
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
Exclamation DIY how to remove door panel ??
Hi guys ...
I need help
i'll be really grateful if someone shows me how to disassemble the door panel from the inside on a sedan ...
THANX
BLOODY_STONE is offline   Reply With Quote
Old 07-01-2011, 12:24 PM   #2
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
2007 Yaris Factory Repair Manual
I'm not sure which part of the manual it's in, but it should be in there. That repair manual gives you the low-down on how to pull apart just about everything on the Yaris!
Old 07-01-2011, 06:33 PM   #3
BLOODY_STONE
only mentioned the screws positions .. clips locations not listed >>>
but thanks anyways
Old 07-01-2011, 10:24 PM   #4
This screen cap from the parts catalog shows the clip locations:
Old 07-02-2011, 03:28 AM   #5
rufnnek
rufnnek's Avatar
Drives: oliveMist
thanks dude...
rufnnek is offline   Reply With Quote
Old 07-02-2011, 09:56 AM   #6
swidd
Drives: Yaris HB
how I do it, on hb:
begin with the three grey panels, just rip them up.
Remove the little clip that's in the front side of the panel (screw driver to pop it off).
Remove 4 screws in the red pieces of plastic inside where the grey panels were.
Rip off door panel.
Before re-installing, check that all the clips you ripped off are in place in the door panel and not stuck in the door. You may need to buy replacements for broken clips (pack of 30 was like $15).
Old 07-03-2011, 08:44 AM   #7
BLOODY_STONE
is there anyway i can remove the part i've shown in red without removing the whole door ??
Old 07-03-2011, 02:43 PM   #8
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Mine is a hatchback so I'm not 100% sure, but it looks like there is just one screw that holds down that control module:
I have many more pictured than what is actually shown here. This should give anyone who wants a look inside the door of a sedan a pretty darned good idea of what to expect with a proper deadening of the door.
My my...this looks like a door:
The power controls removed. It is just one screw and the removal of the control panel:
<snip>
http://www.yarisworld.com/forums/showthread.php?t=17465
-toy
Old 07-03-2011, 04:25 PM   #9
BLOODY_STONE
-toy
THANX !!!! u made my day :-D
DIY - How to remove or insert a pin on the ECM Connector A21 CTScott DIY / Maintenance / Service 6 05-21-2024 01:29 PM
DIY : How to remove door panels FEINT DIY / Maintenance / Service 13 11-18-2021 03:16 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 01:59 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 12:48 PM
