Old 08-15-2011, 01:49 PM   #1
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
Blower fan question
The other day, my Yaris blowe fan starting making a noise. First it sounded like there was something caught in the fan blades. Later it sounded like the bearings were going with a high pitched whine.
Today, nothing. Perfectly normal and same volume of air that it usually puts out at all 4 speeds.
Has anyone else has this same occurrence and if so, did you ever have to replace the blower motor?
Also, has anyone every replaced the blower motor? Where is it at and how hard is it to get to?
Thanks in advance for our assistance!
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 08-15-2011, 01:56 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
You probably don't have a cabin filter and something got sucked out of the glove box and got eaten up by the fan... making a lot of noise in the process. That's what happened to me soon after I got my car, and I also thought the motor "bearings were going..."
Pull the glove box and check for a cabin filter. If you don't have one, then visit your local auto parts store. Don't keep anything loose in the glove box... like gas receipts, for example.
Old 08-16-2011, 02:05 PM   #3
daf62757
daf62757's Avatar
You Sir, are a genius!
I just removed the glovebox and opened the filter cover to discover paper in the blower well.
Thanks for sharing your intelligence!
Big Dave
Indianapolis, IN
Old 08-16-2011, 12:52 PM   #4
josh044
Drives: 07 yaris hb - 5 spd
which glove box is the filter in? I haven't noticed any sort of filter in any of my gloveboxes. I have an 07LB
josh044 is offline   Reply With Quote
Old 08-16-2011, 01:06 PM   #5
BLH
Drives: 2007 Yaris Sedan
Cabin air filter. Is behind the glove box inside the blower housing.
Glove box has to be removed to find it.
The one I bought had an instruction sheet in the box on installing or replacing it.
My 2007 shipped from the factory with it not installed.
Search found this. There are more.
http://www.yarisworld.com/forums/sho...t=Cabin+filter
BLH is offline   Reply With Quote
Old 08-16-2011, 02:16 PM   #6
josh044
Thanks! I'll have to check this out, not sure if I have a filter in place or not.
Old 08-16-2011, 06:27 PM   #7
daf62757
daf62757's Avatar
Mine didn't have a filter. I checked on Amazon.com and order one for 10.99 with free shipping.
Big Dave
Indianapolis, IN
AC Blower Motor / Fan Does Not Turn on Period dyslexicanaboko DIY / Maintenance / Service 7 01-30-2012 10:59 PM
A/C Blower Dismantling? Yaross DIY / Maintenance / Service 9 12-14-2011 03:56 AM
Why wont my fan blower work? lucy7509 DIY / Maintenance / Service 4 08-09-2011 02:48 AM
A/C blower resistor ubear7 DIY / Maintenance / Service 1 08-08-2010 09:53 PM
Question: Yaris' Radiator Fan: Electrical or Clutch-type? TRD_Yaris General Yaris / Vitz Discussion 5 06-11-2006 09:07 PM
