Old 01-25-2007, 03:09 PM   #1
foggy08
Drives: yaris 1.0
dash problems...help needed
the digital dash on my 2001 yaris gs keeps going out .....i went to a breakers and tried a new dash. it lit up ok but it didnt show the mph or revs also it showed my fuel tank as being full when i knew it was only half full....the guy at the breakers said mr toyota might have to set the dash up with the ecu.....is this correct? if so how much would this cost ? or will they have to sell me a new dash as well ?
foggy08 is offline   Reply With Quote
Old 01-25-2007, 09:04 PM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
you might want to try the breakers again and after hooking up the new cluster pull the batt cable for a few secs and then hook it backup to "reset" the ecu
will work for parts
vodkalush is offline   Reply With Quote
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 04:59 PM
Good place to find constant & switched 12V behind dash? atebit In Car Entertainment + Electronics (audio / video / alarm) 16 03-03-2009 11:40 AM
Differences in dash between sedan and HB sroberts General Yaris / Vitz Discussion 13 11-16-2008 11:34 PM
Timing chain, sprockets, & cam position sensor problems? PetersRedYaris DIY / Maintenance / Service 8 01-04-2007 12:50 PM
How do I take apart dash on left side? ryker DIY / Maintenance / Service 5 01-01-2007 06:01 PM
