Old 09-14-2011, 08:58 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Rear sway bar snow clearance?
After a few searches, I can't find a definitive answer on this: does the rear sway bar cause clearance issues with snow?
I've found several posts where people talk about the potential problem, but none that directly answer with experience. I guess if there was a serious problem with it, then there should be some posts warning against installing one in northern climates. On the other hand, there are plenty of YW members in Canada and northern US with them installed.
So anyway, if you drive in snow with one, what's your experience been like?
Old 09-14-2011, 09:12 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Made no impact having it as far as I could tell.
Old 09-14-2011, 10:15 AM   #3
A-Dingo-Ate-My-Baby
Drives: yaris
The TRD one tucks way up under the beam, so no here.
The Ultra Racing hangs lower, but no lower than the
front lip and rest of the bottom of the car, so no on this as well.
If you jam the car into a snowbank of course the ends of
either one will get snow on them,
but no, none of the 2 above bars drag in snow. other stuff will drag first.
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 09-14-2011, 10:27 AM   #4
^ the Ultra Racing sway bar is exactly the same as TRD in terms of shape. It does not hang lower. Maybe you meant the rear underbrace.
Old 09-14-2011, 12:03 PM   #5
A-Dingo-Ate-My-Baby
Drives: yaris
really ? in pics the TRD is shoved way up under. the ultra I have is lower. perhaps i was looking at the wrong TRD photo or for a different car
http://www.google.com/products/catal...ed=0CEMQ8wIwAw
note the extra bend TRD has to go up into the torsion beam, whereas ultra just bends a little bit and doesn't tuck into the torsion beam
Old 09-14-2011, 10:54 AM   #6
Lil Abner
Drives: 2009 3dr LB Manual
Cranky, we're in basically the same part of Michigan. I'm lowered on DF210's with the Ultra Racing rear sway bar, and had NO problems this past winter. The only part that was hitting the snow was the bumper while going through 3-ft snow drifts! I also have no problems on those stupidly large speed bumps.
Old 09-14-2011, 10:58 AM   #7
CrankyOldMan
Wow, thanks for the prompt replies! Looks like a rear sway bar is on my wish list then.
Old 09-14-2011, 11:00 AM   #8
Lil Abner
Move it from your wishlist to your must-have list!
Old 09-14-2011, 11:31 AM   #9
CrankyOldMan
Well, between the xB transmission, NST pulley, MI SSK and shift cable bushings that I bought this week, my funny money is pretty much spent. Had to get the wife a laptop and DSLR camera for her college classes this month too, which put a sizable dent in it to begin with. It's definitely on the list though!
Crap, gotta get snow tires soon too.
Old 09-14-2011, 11:14 AM   #10
poorsh2
Drives: 2008 yaris hb
No problems in last years snow, TRD sway bar
poorsh2 is offline   Reply With Quote
Old 09-14-2011, 12:44 PM   #11
^ Yes it does, looks like they changed the shape at some point. Or that is a picture of a different vehicle. The extra bends will make it less effective.
But either way it's not the lowest part of the suspension so it won't be affected by the OP's concern.
Is this a Yaris?
Old 09-14-2011, 02:56 PM   #12
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
I think that's on a sedan. That's exactly what mine looked like minus trd springs and shocks (edit: and wheels)
NZ-FE Vios is offline   Reply With Quote
Old 09-14-2011, 04:22 PM   #13
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
SWAY BAR doesn't BUT me lowered on TIEN'S causes the front to snow plow effect and pushes snow up into radiator area....
Old 09-14-2011, 04:45 PM   #14
I'm happy (selfishly) if TRD makes it that way now. I means the Ultra Racing product is now better -- lighter and more resistant to twist forces.
Old 09-14-2011, 05:06 PM   #15
A-Dingo-Ate-My-Baby
Drives: yaris
u mean...as heavy as the Ultra racing was, TRD is heavier ? dang
Old 09-14-2011, 05:59 PM   #16
sure - more bends means a longer bar.
Old 09-14-2011, 06:30 PM   #17
RedRide
RedRide's Avatar
It may be just the camera angle that makes it look that way.
Old 09-14-2011, 08:23 PM   #18
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
cali that would be the underside of a scion xd
by that plastic cover towards the rear of spare tirewell
OTA'sTOY is offline   Reply With Quote
TRD rear sway bar? Lewis DIY / Maintenance / Service 26 09-10-2013 02:10 PM
FS: 19mm UR Rear Sway Bar (Socal) dejawu Items for Sale by private party 3 07-08-2011 04:01 AM
wtb rear sway bar, preferably the ultra racing 19mm. swidd Willing to Buy by private party 2 02-26-2011 12:59 PM
Rear Sway LINK BRACE djct_watt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 12-16-2009 03:29 AM
Is the TRD rear sway bar a worthwhile upgrade? YellowJolt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 07-15-2009 08:07 AM
