![]() Drives: Red '08 3 Door Join Date: Jul 2011
DRL wires
Does anyone know where the wires for the drls are, I have an '08 HB and would like to change the DRLs from the main headlight bulb to that small bulb on the inboard side of the actual headlight. I know for the Mk3 Jetta I had my friend moved an wire on the switch itself. Can anyone help me.
Mors Certa, Hora Incerta, Memento Vivere |
The large blue wire in pin 1 of the DRL module is the output. You can clip that wire, cap the harness side and connect the module side to whatever bulb you want to be your DRL.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
You're 08 HB has DRLs? Is that unique to Pennsylvania?
DRLs were part of the "cold weather" package.
where can I find the drl module
Between the steering column and the radio.
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
If you take both panels off from under the steering column you'll find the DRL tucked away right up against the center column (where the radio is) on the bottom right hand side of the panel you just took off.
| Scion XD LED mirror install pics aplenty | enviri | DIY / Maintenance / Service | 76 | 07-21-2019 02:10 PM |
| Ultimate Turbo Pre-Install Guide | Focus_Sh1ft | Forced Induction Forum | 7 | 09-14-2017 03:28 PM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 11:48 AM |
| Hid bi xenon problem need to keep drl due to fogs | marcus | Cosmetic Modifications (Exterior/Interior) | 4 | 06-20-2010 12:01 PM |
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 06:37 PM |
