![]() Drives: 2007 toyota Yaris Join Date: Jan 2011
where is my horn located? 2007 3 door
I bought this Yaris three years ago and everything always worked except the horn. This unit had a salvage title and I was told that it was hit relatively lightly in the front end. (It may be a salvage title but its the best car that I have owned and I am 53 years old) A friend and I searched for the horn one day and was unable to find it, I was wondering if possibly if the horn was damaged and was removed but not replaced. Not a big deal as I am not much of a horn blower anyway but still like to have everything in working order. Any insight from this very knowledgable forum would be much appreciated. thanks
As you look at the front of the car and through the upper grill opening, it should be hanging down in front of the right half of the radiator. It attaches to that upper brace with one bolt.
2ZR swap. DO IT! Ask how!
You should be able to see it through the upper grille, but you have to take off the whole bumper to access it.
basically behind the grill, but on the other side of where i had my hella...
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Check out the repair pdf:
http://www.etimago.com/yaris/repairmanual/Horn.pdf |
Thanks
Thanks Guys, If it were a snake it would have bitten me. Now I can start looking for the problem. I especially thank you Revsson for the repair link.
You're welcome Suey.
BTW, the entire repair manual is under the DIY/Maintenance/Service area or at: http://www.etimago.com/yaris/repairmanual/ Lots of good info there, much of it beyond my abilities, but helpful. I replaced my horn with the Toyota Premium horn kit when I installed fog lights, so I had the bumper off to work on the horn. |
| DIY: Replacing 2-Door Liftback Door Panel Fabric | redyaris | DIY / Maintenance / Service | 25 | 06-25-2024 01:24 AM |
| Need to install a 2007 door on a 2009 model. Help! | neelieflower | DIY / Maintenance / Service | 5 | 11-20-2011 01:20 PM |
| F.S. 2007 Toyota Yairs/Vitz RS 5 Door hatchback $12,500.00 OBO | Ric n Sov's Vitz RS | Items for Sale by private party | 5 | 06-14-2011 10:56 PM |
