![]() Drives: 2007 Yaris Sedan 4 Door Join Date: Jun 2007
little black arm/hinge on door??
ok, funny question, does anyone know what the official name of that part is? its the little black plastic arm on the back doors that functions like a sliding hinge, guess prevents door from opening all the way or something
strange thing is that yesterday I tried to open one of the back doors and it just stopped half way, it was greased and stuff, now it seems like its grinding on something opening and closing, how does this thing work? it slides inside the door, is it a simple thing or does it have bearings? etc thanks |
Drives: yaris Join Date: Jan 2011
#3 | |
#4 | |
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
Open the door all the way open. Might have to again use little pressure to open it all the way. Put some light oil (wd40) or the like on the bar portion of the stop check mech. Be sure to do the upper AND lower part of it. Close the door and open all the way repeatedly and most likely the movement will become easier. It sometimes gets "tight" when the mechanism does not travel over a spot often enough. (partially opening the dor all the time, vs opening the door all the way). I'll bet you "fix" the problem without lifitng a tool! Good Luck! |
| Door Handle LED DIY with pics | window_lee | DIY / Maintenance / Service | 93 | 05-31-2012 11:58 PM |
| California May Ban Black Cars | MadMax | California | 69 | 12-09-2009 10:44 PM |
| Where can I get door edge protector? black rubber** | Blenjar | Cosmetic Modifications (Exterior/Interior) | 5 | 03-13-2007 01:29 PM |
| Possible 4 door Yaris stateside? | ElViShGiBbErIsH | General Yaris / Vitz Discussion | 19 | 05-18-2006 06:03 PM |
