Old 09-03-2009, 07:56 AM   #1
window_lee
Drives: Yaris RS 2007
Door Handle LED DIY with pics
Finally I have time to take some pics of the DIY. Since my english is very poor, I will use pics instead of speaking. Hope this will help and feel free to ask questions and add comments.
I am having a 5 Dr yaris, so I will start with the front door and you can get the LEDs from Walmart for $10 (4 of them)
1. open the front door and locate the black stuff which cover the screw and remove it
2. unscrew the screw (the screw has something to hold on to it, so no worry it will fall into the door)
3. after you unscrew it, remove the lock and the handle
slide the handle toward the back of the car and remove it
4. drill a hole in the handle and put your LED in it (I used hot glue to keep the LED in place)
5. run the wire in the door and through the wire tube into the car
Now come to the rear door
6. For the rear door, we have to remove the lock in order to get to the screw, so we have to remove the door panel and there are only two screw for the door panel.
7. remove the cable for the lock and unplug any wire for the power window or whatever u have.
8. after remove the door panel, u can unplug the wire and remove the lock
9. u will be able to see the screw after u remove the lock
10. remove the door handle the same way u do for the front door
again run the LED wire through the wire tube into the car
Now u can connect your LED wherever u want. I run the wire to the keyless dome light circuit, so when i open the door, this will come on
Hope u guys like it
window_lee is offline   Reply With Quote
Old 09-03-2009, 08:09 AM   #2
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
Do you have any pictures of them fully installed and turned on at night?
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Old 09-03-2009, 10:11 AM   #3
nick.dollimount
Yaris = <3
That looks wicked!=D
..:'; Nick ;':..
Old 09-03-2009, 10:49 AM   #4
mrbond
mrbond's Avatar
Where was the keyless dome light circuit in your car? What I mean is, how far did you have to thread the LED wire into the car?
It looks awesome, by the way.
- A Toyota Yaris
- A whut Yaris?
Old 09-03-2009, 06:49 PM   #5
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
+1
Old 09-03-2009, 06:50 PM   #6
window_lee
where I connect my LEDs is very close to the dome light, so the LED wire is long
Old 09-03-2009, 07:47 PM   #7
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
[QUOTE=window_lee;378648]Finally I have time to take some pics of the DIY. Since my english is very poor, QUOTE]
Where you from? because your english is not bad at all compared to the people I talk to all day long!
good DIY! might look into this very soon also!
the_boss is offline   Reply With Quote
Old 09-03-2009, 07:51 PM   #8
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
dude that's awesome, and awesome pics, thank you :)
BuildCode is offline   Reply With Quote
Old 09-03-2009, 08:54 PM   #9
window_lee
[QUOTE=the_boss;378990]
I am from Hong Kong and now i am in Canada
Old 09-04-2009, 08:23 AM   #10
nick.dollimount
Yaris = <3
[QUOTE=window_lee;379039]
What part of Canada?
..:'; Nick ;':..
Old 09-04-2009, 12:39 PM   #11
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
very cool seems easy but i am kinda inpatient for this kinda stuff. How lond did it take u?
Originally Posted by sw07gt
Old 09-04-2009, 07:28 PM   #12
window_lee
[QUOTE=nick.dollimount;379302]
I am now in Kamloops
Old 09-04-2009, 07:29 PM   #13
window_lee
It took me half day to get everything done, since I had to remove many stuffs in order to run the wire
Old 09-04-2009, 07:37 PM   #14
absolutely BRILLIANT.
Old 09-05-2009, 02:27 AM   #15
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
How did you come up with this idea? Cause its B E Autiful.
Red Horse is offline   Reply With Quote
Old 09-05-2009, 02:57 AM   #16
djgab101
djgab101's Avatar
Drives: toyota yaris
u can find these lights on the new bmw 135i twin turbo
djgab101 is offline   Reply With Quote
Old 09-05-2009, 03:37 AM   #17
window_lee
I got this idea from a BMW ahhahaha
Old 09-05-2009, 10:09 AM   #18
mrbond
mrbond's Avatar
^ this idea was also in the Vitz Hyper Rev. There's a lot of things you can do with LEDs, as y'all can see with the pictures.
- A Toyota Yaris
- A whut Yaris?
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
