![]() Drives: Bronco2, S10Blazer,Caliber Join Date: Jan 2012
Cruise on '06??
What's the final word on adding cruise to an '06 auto tranny? Is it prewired? Do I need to add anything else as far as modules? I read the forum but there is alot of BS chatter in it.
Your 06 can do cruise control, but it is not prewired. You will need the stalk and will also need the ECM connector pin and the connector D3 pins. My DIY below has all of the details. I have some of the stalks and all of the pins required available, if you need them. I also make a module that drives an LED as an indicator that cruise is on, since the 06-08 Yaris do not have the indicator in the cluster as the 09+ do.
http://www.yarisworld.com/forums/showthread.php?t=33750
![]() Drives: 2008 Yaris 3-dr Hatchback Join Date: Feb 2012
CTScott,
Do you still sell a cruise control package? If so, how do I go about getting it? I have a 2008 manual 3-door. I am new to the whole forum thing also. |
PM sent
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control for 2012 European made Yaris | CTScott | DIY / Maintenance / Service | 1 | 12-27-2011 06:47 AM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
