Old 03-10-2012, 11:28 AM   #1
theidiots
Drives: Yaris 3 Door Hatchback
Drilling into the floor
Cause it is fun.
No. Because I want to install one of these.
http://www.amazon.com/Arkon-Tablet-S...1396398&sr=8-1
The 07 Yaris seat bolt bracket does not sit flush to the floor allowing for the simple install.
It looks like I'll need to drill the alternate bracket into the floor. Is there a spot near the front seat that I can drill into or a spot NOT to drill. I'd hate to find the gas line.
I was thinking of drilling into the raised spot on the floor that the seat is already bolted to - somewhere between the seat bolt next to the center console and the VIN under the carpet.
Thanks!
theidiots is offline   Reply With Quote
Old 03-10-2012, 11:35 AM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
It looks like one of those brackets is meant to go under a seat bolt. Why can't you do that?
Old 03-10-2012, 11:54 AM   #3
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
You do not want to drill. Onc you break the surface of the metal (on any part of the car) it WILL rust unless you know how to treat it properly.
Old 03-10-2012, 12:01 PM   #4
Originally Posted by theidiots View Post
Cause it is fun.
Thanks!
The raised area that the front of the passenger seat bolts to is a perfect place to drill. It is a U shaped piece that is welded above the floor, so you will not be drilling to daylight. The only thing that runs through it is the plastic rear AC duct.
Old 03-10-2012, 02:09 PM   #5
theidiots
re: why not put the bracket under the bolt?
No room. The seat bracket is shaped like a cup on the Yaris. The bracket does not fit right.
I also found a screw under the passenger side dash that looks to hold a fan motor. It screws into plastic and I can't get it tight enough.
I think I'm going to take the advice of the guy that turned his Yaris into a plow.
THANKS EVERYONE.
Old 03-10-2012, 03:10 PM   #6
theidiots
Well, so far. I have broken a drill bit and twisted apart two screws going through that steel.
Stick around for updates.
Old 03-10-2012, 11:49 PM   #7
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
unless you are building the yaris into a police cruiser, why do you need a tablet in the car?
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 03-12-2012, 06:22 PM   #8
TOLMACH
Drives: soarer
.wav and .flac files
Old 03-12-2012, 02:12 PM   #9
theidiots
So, I can see my MP3 player.
So, I can use GPS.
ANGRY BIRDS - Duh!
Same reason someone would put a slot car track in the hatch. Because we can.
Anyway, it worked and I don't smell gas or see the road.
Thanks guys.
Old 03-12-2012, 04:26 PM   #10
Reeves360
Drives: 09 Yaris Sedan, 91 ToyotaTruck
Send a message via AIM to Reeves360 Send a message via MSN to Reeves360 Send a message via Yahoo to Reeves360
Bolts and Washers?
Why not get a longer bolt for the seat and then use some metal washers so you can attach your tablet mount?
I'm not sure if that would cause a safety problem with the seat though, anyone know for sure on that? Maybe use really strong steel washers?
Personally I would just shell out the cash for a ProClips or similar mount that fits and holds to the groves of the dash trim.
Reeves360 is offline   Reply With Quote
Old 03-14-2012, 02:37 PM   #11
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
if i see you on the road playing angry birds while driving , you'll be the pig...trust me
how bout focusing on the road
+1! Maybe the OP's name fits???
DebbyM46227 is offline   Reply With Quote
Old 03-12-2012, 10:55 PM   #12
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
porn-on-the-go
Old 03-16-2012, 02:50 PM   #13
theidiots
Maybe the name fits. It probably fits all of us.
But really - relax folks. Ever hear of an MP3 player or GPS? My tab does both and now the tablet sits right next to my radio controls.
Besides, I can't play Angry Birds while driving. I'm too busy with that slot car track and trying to stay on the road. You try racing a slot car by looking only in the rear view mirror with one eye.
Old 03-16-2012, 03:13 PM   #14
TRDMarty
Just keep drilling until you get it to work.
Post the finished pics!!
Old 03-16-2012, 03:48 PM   #15
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Yes, pics please. I'd like to get the same mount. How does it perform? Does it bounce a lot, or is it pretty stationary?
goliath1812 is offline   Reply With Quote
2010 White 3dr / A Pillars / kicks / sound deadening / new false floor / etc... 3cyltrbo In Car Entertainment + Electronics (audio / video / alarm) 39 08-21-2015 12:06 PM
The Official *MAD DOG* jokes thread v2 *MAD DOG* Off-topic / Other Cars / Everything else Discussions 771 05-22-2013 11:25 AM
Wet floor on the passenger side? Got it! nemobile DIY / Maintenance / Service 8 01-20-2012 12:57 PM
Hole in floor mat from aggresive driving! YarisSedan Cosmetic Modifications (Exterior/Interior) 6 10-01-2009 02:36 AM
DIY Floor mats chadmw06 DIY / Maintenance / Service 5 08-30-2006 12:47 PM
