Old 08-23-2011, 10:14 PM   #1
nemobile
Drives: Yaris 09 Sedan
Wet floor on the passenger side? Got it!
Hi, all Yaris owners!
This is my first posting on this forum, and I wanted to share my experience with my Nemobile, Yaris 09 sedan.
I bought this used car from a dealer in Summer 2010. After a while I noticed that the passenger side floor gets a little bit wet. Soon it was very wet, and I had to google the symptom and reasons.
Possible reasons I found were:
1. AC Water Leak
2. Rain Leak
I suspected AC water leak because the floor gets wet only in Summer. But then I was too lazy I totally forgot about it after the Summer.
In this Summer, it was uncontrollable. Even the floor of the back seat was wet, so I had to lift the floor and see what's going on. I have to tell you, there was a lot of water under the floor. I sucked all the water out with dry&wet vacuum, and lifted more floor. Finally I found that the end of the hose that takes AC water out of the car was not in the place and it was inside the floor. This was located at the foot area of passenger floor. I had to put it back in the whole and seal it with silicon.
Attached image is the pic of the spot.
Now the floor is getting dry, and I don't see the symptom happening anymore. And also I realized that the AC makes a lot of water. lol
Just in case if anyone has the same issue, I hope this helps.
>> Nemobile, my favorite toy! <<
nemobile is offline   Reply With Quote
Old 08-23-2011, 10:31 PM   #2
Revsson
Welcome to YarisWorld!
Maybe it was the earthquake that shook it loose?
Old 08-24-2011, 08:13 AM   #3
Lil Abner
Drives: 2009 3dr LB Manual
Good info. Thanks!
Old 08-24-2011, 04:31 PM   #4
nemobile
Haha good one, Revsson! ;)
Old 01-18-2012, 05:41 PM   #5
keatonh
Drives: yaris
Thank you!
This same thing is happening to my son's car.
keatonh is offline   Reply With Quote
Old 01-18-2012, 07:46 PM   #6
auxmike
auxmike's Avatar
I can't believe that hose was'nt properly run through the hole in the floor!
My car started having the same problem. I completely removed that rubber hose and drained all the built up water into a folded towel little by little. I found the hose full of what appeared to be spider webs.....
Old 01-19-2012, 11:16 AM   #7
RedRide
RedRide's Avatar
I had the same thing happen with my old Ford Probe.
Yes, it's amazing how much water an AC can dump into the interior if it can't drain properly.
Old 01-19-2012, 11:22 AM   #8
auxmike
auxmike's Avatar
Yeah, mine was so full it was making the vent blower act erratic due to water getting into it.
Old 01-20-2012, 12:57 PM   #9
Geoff Peace
Drives: Yaris 1.33 litre 2011
Another point about this drain which I found out last winter. I too had a wet passenger floor, the reason was the windscreen was iced up so I thawed it with warm water. the drain in question had obviously been freezing and thawing repeatedly and had finally frozen solid, so the drain backed up to the heater with the water I was putting on the windscreen and drained into the car! Probably a good idea to check if it is free from time to time.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
carpet wet passenger side dadmansfield DIY / Maintenance / Service 28 10-04-2022 05:51 PM
A/C only blowing out of passenger side? devinlamothe DIY / Maintenance / Service 24 08-08-2011 05:50 PM
Switched Power Behind Passenger Side Glove Boxes? IsLNdbOi DIY / Maintenance / Service 10 07-05-2011 08:25 PM
WTB - Passenger Side Seat Bracket lunjiaow Willing to Buy by private party 3 09-08-2009 05:03 AM
Passenger side airbag question rizaydog In Car Entertainment + Electronics (audio / video / alarm) 0 01-03-2009 07:54 PM
