Old 06-30-2011, 03:00 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
Switched Power Behind Passenger Side Glove Boxes?
I have an '09 5-door LB. I'd like to add another DC outlet like this:
http://www.radioshack.com/product/in...ductId=3896268
to the upper passenger side glove box.
Are there wires carrying switched power behind the passenger side glove boxes? If not, are there any switched power wires on the front passenger side?
Heatware:
http://www.heatware.com/eval.php?id=35947
Old 06-30-2011, 08:00 AM   #2
You can either tape the center console lighter outlet or on the actual passenger side, you can tap the red wire on the end of the black connector for the TPWS.
Old 06-30-2011, 08:10 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
Thanks CTScott. Where is that black TPWS connector and sorry for my ignorance, but what is "TPWS"?
Heatware:
Old 06-30-2011, 08:55 AM   #4
Tire Pressure Warning System. The TPWS ECU is the 4"x4"x1" black box mounted right behind the lower passenger glove box.
Old 07-02-2011, 06:20 AM   #5
IsLNdbOi
IsLNdbOi's Avatar
Ok, I tried tapping into each of the red wires (there were two) on the black connector for the TPWS, but neither worked. I even used one of these to test if it was working:
I also managed to break the car's stock cigarette lighter outlet while I was doing this. When I plug anything (GPS, iPhone car charger, etc.) into it now, nothing happens. Could be a blown fuse, but I don't know how to replace that.
Heatware:
Old 07-02-2011, 07:34 AM   #6
Check the ACC and ECU-IG fuses in the under dash fuse panel. You probably popped them.
Old 07-02-2011, 07:38 AM   #7
IsLNdbOi
IsLNdbOi's Avatar
The part where I "broke" the cigarette lighter outlet and probably blew the fuse was after I tried tapping into those red wires.
I'll take it to the dealer tomorrow so they can replace the fuses for me.
Thanks again.
Heatware:
Old 07-02-2011, 07:44 AM   #8
IsLNdbOi
IsLNdbOi's Avatar
If the ACC and ECU-IG fuses are out, is the head unit supposed to work still?
Heatware:
Old 07-02-2011, 07:57 AM   #9
IsLNdbOi
IsLNdbOi's Avatar
Last question for now; How are the fuses supposed to look if they are burned out? I just pulled them out, but couldn't tell if they were burned out or not.
Heatware:
Old 07-02-2011, 08:02 AM   #10
The little metal U will be missing a piece.
Old 07-05-2011, 08:25 PM   #11
IsLNdbOi
IsLNdbOi's Avatar
Looked at the ACC and ECU-IG fuses and they both looked normal so I looked at all the rest and the one labeled "CIG" was the one that blew out. Haven't tried tapping in to the TPWS connector again.
Heatware:
DIY: Colibri Power Window Install Taiyaki DIY / Maintenance / Service 15 04-28-2016 09:03 PM
Looking for Passenger side Fender! Marthos Willing to Buy by private party 1 07-21-2011 08:13 AM
WTB - Passenger Side Seat Bracket lunjiaow Willing to Buy by private party 3 09-08-2009 05:03 AM
Passenger side airbag question rizaydog In Car Entertainment + Electronics (audio / video / alarm) 0 01-03-2009 07:54 PM
Anyone know how the passenger seat detection system works? rage2 DIY / Maintenance / Service 5 05-12-2007 07:22 PM
