![]() ![]() Drives: Yaris 3dr hatch Join Date: Jan 2012
Passenger airbag light on making turn signals and cabin fan not blowing?
Not sure where the best place to post this was. Title says it all. If someone is sitting in the passenger seat the airbag light turns on and all of a sudden my turn signals no longer work and my cabin air fans dont turn on. Asked my fiance' to get up and let the airbag light turn off and suddenly the turn signals work again but the fans still dont blow air out. strange problem. anyone else had this or know of a solution to this??
Thanks! |
started happening when I installed my O2 anti-fouler if that helps any or if that would effect any of that. I dont have much knowledge on car wiring and electronics.
![]() ![]() Drives: 2009 yaris sedan Join Date: Apr 2011
o2 anti fouler?????
sounds like a loose ground connection somewhere or a few blown fuses.. |
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
I thought it was normal for the passenger airbag light to be on when someone was sitting in the passenger seat. Mine has come on from Day 1. I also have the passenger airbag light "off" light that comes on when I have something small in the seat, like a jug of milk. I suppose it thinks there's a baby in the seat, not a jug of milk.
it is normal for it to come on but I am just saying the problem only occurs when I put stuff in the seat heavy enough to trigger the airbag light or someone is sitting there. I've checked all of my fuses and nothing is blown. Im going to look for a loose ground somewhere.
The passenger airbag indicator is driven from the 10A GAUGE fuse. That same fuse supplies the control side of the relay for the blower motor. That fuse is in the under the bottom of the dash fuse panel.
The flasher relay also works off of that fuse.
ctscott saves the day once again!!!
In my experience thats what you get when you install aftermarket electronics sometimes.
Disconnect it and see if your problem goes away. My advice never install a theft alarm unless you dont want your car to start. Who would steal a Yaris?ECHO?
#10 | |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Sep 2009
Only Happy When it Rains
who cares, if I can recover the cost of the alarm system with the reduction in insurance costs in a couple of years then it is very much worth it.
Colin Chapman disciple |
#12 | |
PS. I feel like a numbskull. first thing I did was pull all the fuses because I had no clue which one ran any of that equipment and in the frustration of laying under the steering wheel I must have skipped that one GAUGE fuse because it was blown. replaced and everything works perfect now. ugh haha. Thanks CTScott! My fiance' appreciates the help even more now that we have A/C :D And thanks everyone else who gave input as well! |
#13 | |
Still...the number of cars i have seen with aftermarket alarms with electrical gremlins can be counted on the fingers and toes of both hands and feet.
#14 |
did the owners do the work themselves? Unless I had the technical aptitude of CTScott I'd let a pro do that type of install. I've had an aftermarket alarm on all my cars and never had any problems.
#15 |
As an FYI, the OP found that it was the fuse that I mentioned above.
#16 |
lol, yea that is pretty dumb. Even a turbo yaris wouldn't be taken for more than a joyride though, the Yaris market simply isn't lucrative enough. Especially when thieves can grab a Camry or Accord and chop it up and sell the parts individually.
#17 |
![]() Drives: 2008 Toyota Yaris S sedan Join Date: Apr 2022
No blower motor, turn signals, airbag light on, defroster light on
All fuses are good under the dash and in the engine compartment. Any idea of what relay might be involved in all these common issues?
Thanks for any and all advice and direction, Steve |
