play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
TRD rear sway bar...
I can now confirm that the TRD rear sway bar also fits the 2012 models.
![]() ![]() ![]() When stuff like this (and the header) says "fits 07-08" I always get a little creeped out but figure what's the worst that can happen? Ship it back, pay a restocking fee, and move on. So I don't mind being a 2012 model lab rat. ![]() I can also report that the TRD sticker fits the 2012 models too... ![]()
And what's your driving impression with the anti-sway bar?
TRD emblem looks cool! |
play every day
Don't know yet because I just put it on this evening and we haven't gone anywhere except to take a hike in the hills to see the big full moon at perigee just as it was rising tonight.
![]() ![]() ![]() Drives: 2012 Yaris 3-door w/5-speed! Join Date: Nov 2011
I anxiously await a report after your road test. I already love the '12's sharp handling (for the class of car), but I will totally buy and install one of these, if the sharper handling is there.
play every day
Sure. I'll let you know.
![]() The bar only took about 20 minutes to install and is as close to an absolutely perfect fit as you can get. Fits onto the lower rear shock bolts, which are already long enough to accept the bar. Two other supplied bolts attach it to the trailing arm which has perfectly positioned holes. I noticed something interesting about the bolts... There is a flat washer under the head of the bolt and serrations stamped into the underside of the nut, so the bolts remove much easier by turning the bolt head rather than the nut. Same with installing. I just snugged them down by hand and turned the bolt heads with just one wrench because the serrated nut bites in and holds its position without needing to be held with a second wrench. |
#6 | |
![]() Drives: 2012 yaris Join Date: Apr 2012
how much does it cost?
play every day
Didn't find any deals so I just paid the going rate. It was $176 with free shipping and no sales tax off of Ebay. Dealers sell them for the same price, about $150 plus sales tax and shipping. I believe it's worth it because the value of improved handling is greater than the cost.
![]() Drives: 2012 3 door LE Join Date: Apr 2012
part number?
play every day
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Any noticeable improvements in car handling?
#12 | |
play every day
From post #8...
![]() Quote:
^ Thanks!
#14 |
![]() ![]() Drives: 2012 Join Date: Mar 2012
I had one on my 2007 and now have one on my 2012. It is the best modification you can make for your money. The difference in handling is immediately apparent and very significant. It makes the car handle much flatter and it is especially noticable when taking a sharp turn quickly. You can get a real TRD one one at partsnet.com for $149 with free shipping if you use the pull down menu for shipping method.
#15 |
I am puzzled, I thought the track on the '12 was wider than earlier Yaris?
#16 |
play every day
The wheelbase is a little bit longer.
2011 96.9" 2012 98.8" |
#17 |
The width of a 2011 Yaris 3 door lift back is 66.7 inches as is the width of a 2012. The width of the five door is the same as the 3 door for both years.
#18 |
I have this on my '08 hatch. It firms up the rear real nice. I paid $152 in '08 so the price has remained fairly stable.
Never take eyes off opponent - Bruce Lee |
| My Ultra Racing rear sway bar install | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 49 | 03-03-2011 02:08 AM |
| Which rear sway bar? | IsLNdbOi | Performance Modifications | 46 | 11-05-2009 06:07 AM |
| TRD rear sway bar | cali yaris | Items for Sale by private party | 19 | 05-23-2009 05:23 PM |
| Does the TRD rear sway bar promote tire wear? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 03-29-2009 10:29 AM |
| TRD sway bar and tire wear | Cutie Pie #2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 02-01-2009 08:07 AM |
