Old 06-24-2012, 08:15 PM   #1
biggyjiggy
Drives: 07 Red Yaris LB
07 yaris lb sometimes does not start :(
Hi everyone! I just got my yaris (manual 5spd) last week with 25,000 miles on it.
For some odd reason the car runs perfectly fine but then sometimes when i try to start my car it doesnt turn on. For example today i went to sports authority and 15 minutes after i had bought what i needed the car wouldnt start. I always start it with it in 1st gear, clutch in and turned ignition. however, today when i did that at sports authority it didnt start. I'm sure the battery works fine cuz when it wasnt starting, the radio and fan still works. (i dont have power windows or locks). Ohhh and when i turn the ignition to start the car there is no sounds. no clicking of the starter. :/ im not sure if its the starter or the clutch. but with the current mileage it doesnt make sense that the clutch would be worn out or the starter.
Any ideas?
The car does have a custom alarm system installed by the previous owner. To me i think that might be causing a problem with the relay to start the car. I've experience this problem in my previous car. there was a relay connected to the relay that starts the car when someone installed a custom alarm system. I figured id ask around here first before deciding to bring it to the mechanic.
Any advice would be greatly appreciated :)
-Marc
biggyjiggy is offline   Reply With Quote
Old 06-24-2012, 08:32 PM   #2
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
The Custom alarm could very well be causing it as ive seen that before too.. Id check the cable to the starter to make sure it has a good connection.. Ive never had a manual car but it has to be in neutral or the clutch engaged to start, im assuming there is a switch somewhere for this? But all in all, an aftermarket alarm will always be at the top of the list to check out..
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 06-24-2012, 11:10 PM   #3
biggyjiggy
Thanks ill check it out! :)
Old 06-24-2012, 11:15 PM   #4
edmscan
edmscan's Avatar
Drives: 2020 Corolla
There is a switch on the clutch pedal (safety feature on the Yaris) and if it is not depressed ALL THE WAY .. the car will not start.
But I have discovered it is very simple (and no fault of the car) .... I have "winter floor mats" in my car and they are quite deep and sometimes they prevent the clutch from being fully depressed. I turn the key and nothing happens just as described. It took me a while to determine what the problem was .. and like you I was thinking something was wrong with the car.
So I just have to be careful and make sure I am depressing the clutch "all the way" and the car starts just fine.
edmscan is offline   Reply With Quote
Old 06-24-2012, 11:46 PM   #5
biggyjiggy
so are u suggesting to check the floor mats and turn off the safety switch?
im not sure if i have the winter floor mats like u. i think i have the carpeted all season ones. ill be sure to check it tomorrow morning :)
Old 06-24-2012, 11:50 PM   #6
edmscan
edmscan's Avatar
Your case may be different .. but the cause is probably the same. I was perplexed when I couldn't start my Yaris. But it was really that the pedal wasn't being pressed far enough.
I wouldn't remove the switch (even if you could) ... as it is a safety feature if the car is in gear so that it will not go any where. Especially if you like to start your car while it is in gear.
So .. just be aware that you may not be pressing the pedal in as far as is needed. I am pretty sure that this is probably the cause of your problems. Been there ... did that. But now that I am aware of the issue .. I just make sure I press it all the way, and no more problems.
Old 06-24-2012, 11:58 PM   #7
biggyjiggy
mmkay thanks that makes sense.
I just checked the mat right now and the pedal does not make contact with the mat. (i used my hands and felt where the clutch was making contact and at the place it was making contact the rug is not there)
ill double check in the daylight.
Old 06-25-2012, 02:56 PM   #8
biggyjiggy
I got the car checked out. I got the alarm taken out and it turns out that the battery of the car is bad. Seems about right since the car is like 5 years old and hasn't been used much.
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 11:53 AM
Let's start a Yaris Club, each member has a specific number decal Yawesh General Yaris / Vitz Discussion 48 04-10-2009 10:49 PM
