#1 | |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
But I have discovered it is very simple (and no fault of the car) .... I have "winter floor mats" in my car and they are quite deep and sometimes they prevent the clutch from being fully depressed. I turn the key and nothing happens just as described. It took me a while to determine what the problem was .. and like you I was thinking something was wrong with the car. So I just have to be careful and make sure I am depressing the clutch "all the way" and the car starts just fine. Last edited by edmscan; 06-25-2012 at 12:45 AM. |
#2 | |
![]() Drives: 07 Red Yaris LB Join Date: Jun 2012
so are u suggesting to check the floor mats and turn off the safety switch? im not sure if i have the winter floor mats like u. i think i have the carpeted all season ones. ill be sure to check it tomorrow morning :) |
#3 | |
I wouldn't remove the switch (even if you could) ... as it is a safety feature if the car is in gear so that it will not go any where. Especially if you like to start your car while it is in gear. So .. just be aware that you may not be pressing the pedal in as far as is needed. I am pretty sure that this is probably the cause of your problems. Been there ... did that. But now that I am aware of the issue .. I just make sure I press it all the way, and no more problems. |
mmkay thanks that makes sense.
I just checked the mat right now and the pedal does not make contact with the mat. (i used my hands and felt where the clutch was making contact and at the place it was making contact the rug is not there) ill double check in the daylight. |
I got the car checked out. I got the alarm taken out and it turns out that the battery of the car is bad. Seems about right since the car is like 5 years old and hasn't been used much.
Good to see that you got your car fixed .. having car issues are never fun no matter how small they may be.
Hi guys! i guess the battery was a contributing factor butt... My car still has problems starting... actually more so than ever. It started happening again saturday.. it wouldnt start for an hour then i walked back inside the house for a lil bit and came back out to start it and bammm it started up!! wtf!! right??? lol anyways i was getting anxious but decided to look it over it was probably like a temporary thing i just got the battery replaced...
Next day I went to winco to buy some stuff for me and my gfs picnic and then i tried to start the car.... nothing, car is unresponsive :( the only thing that works is the accessory(radio, fan, ac, defroster, lights on dash, wipers) i dont understand why it wouldnt start... Then I noticed something.. When the lights on the dash (the MPH gauges and gas tank gauge) are on while pushing in the clutch and turning the ignition the car starts.... however when i push in my clutch and turn the ignition the lights automatically shut off once the clutch is pressed and then the car does not start :/ I also noticed that when i push the safety button (for the clutch) seperately from pushing it with the clutch it does the same thing (lights on dash turn off) sooooo im guessing this safety button underneath the clutch may have something to do with my car not starting. Does anyone know of or heard of this happening before with their yari? |
| yaris won't start, engine truns over but won't start. | zara616 | General Yaris / Vitz Discussion | 16 | 09-05-2021 12:39 PM |
| Yaris starts then it wont start. | wush11 | General Yaris / Vitz Discussion | 18 | 01-05-2011 12:53 PM |
| Let's start a Yaris Club, each member has a specific number decal | Yawesh | General Yaris / Vitz Discussion | 48 | 04-10-2009 11:49 PM |
